German Layout
sthoeft
Would be nice to have a German Layout (qwertz with the "umlaute" ä, ö, ü). German dict. would also be nice to have but not a must for the beginning.
as I will do the swiss qwertz keyboard, you will be able to use it as well (without the dic, at the moment)
it has been added in v1.6.0!
walda
when we longpress the a,o,u we get a popup for the "umlaute". when we longpress "s" we need one too for our "ß" like in "Staße" or "muß", we can also write "Strasse" "muss" but with the "ß" it is more correct.
Thx
Walter
Sorry it disappeared in a previous release, I will re-add it !
fjklammer
Hello!
Can you please add a second german layouts: one without the "umlaute" ä, ö, ü - the keys are currently too small.
Currently i use "English (International)" instead of german. but then i have no german dictionary. As i've read in the shop-comments I'm not alone with that wish.
PLEASE!!!
regards
Franz
garugc
I have installed the german dictionary and in the language settings, I have set to "German + äöü"..
but I cannot write with äöü.
only the suggestions have "Umlaute", but when I type a word, and longpress on a key, it just writes a number.
What can I do?
(sorry for my bad english :-)
I don't understand... don't you have the üöä keys directly on the keyboard?? (on the right side)
garugc
Sorry, I forget to say that I dont use the qwertz-keypad.. I use the T9 pad.
and there are no extra keys for äöü
ah ok.. then indeed you can't at the moment. T9 only supports english (without accent) and russian layouts, but it will be improved in future versions
han_swurst
Oh yes please add Umlauts to the T9 layout. Not as extra keys but as longpress suggestions :-) as they are in the compact layout.
please please
greetings
Chris
