I've had a problem with the Long Press Key Preview Pop-up since it was implemented earlier this year. I have Moto-Droid 2.1 and if i press & hold for the minimum amount of time required to activate the alternate character, which I always try to do for speed & efficiency, the blue
pop-up will get stuck on screen and that character will not be entered into the text box. A tap anywhere on screen will apply that previewed character. If I switch applications while that preview is stuck onscreen, the blue preview will sometimes stay on screen above any other application, without the keyboard being displayed.
I'd prefer not having the alternate character previews as they don't help me and it seems to slow typing speed. It would suit me to have an option to just disable showing the blue alt char pop-ups.
Thank you, love this app!
