Key Press + Capitalization issue.
Kodros
Great work on this app so far, but here is an issue that is driving me insane. This occurs on the stock keyboard also so this may be an issue with the framework itself. If I press a key and then quickly press the capitalization button, the keyboard turns into upper case but then quickly turns back to lower case. So the workaround is that you have to pause for a second before you want to capitalize something before you can press the capitalize button.
that's right... I suspect this kind of bug will be a pain to fix, but I'll have a look some day if I have time
