My auto text does not work with my new Galaxy Nexus. I had no problem with it on my DroidX. Please help!
Custom Auto Text in Galaxy Nexus
Same issue. No text suggestions when typing.
Is it only with AutoText, or in general? Is the User dictionary working?
I have no problem on Xoom with Ice Cream Sandwhich, which should work exactly the same...
when i type in any text box, i do not get any word suggestions above the keyboard. i have to type in the whole word. UGH!
Do you mean the suggestion bar doesn't appear, or only the typed word is suggested?
Is "English for Smart Keyboard" installed? Can you check your phone logs (with "adb logcat" command or "Log Collector" app) to see if there are errors when you start typing in a field?
ok, i am an idiot! thanks for your help, that did the trick.
Yes the user dictionary is working and I get the word suggestions in orange but the auto text where I want to use for example type l > Leah is not working at all. I also have the problem where the keys pop up when touching them but the letter on the pop up key is almost transparent. This is also the case when long pressing the chosen word inthe suggestion bar to save to dictionary. I didn't have this problem before 4.0. Any help?
Sent from my Galaxy Nexus using Tapatalk
Galaxy Nexus --- I am experiencing.problems.with the suggestion bar appearing in landscape mode. Appears fine in portrait. Primarily when in messaging applications
Will we be getting a fix for the auto text anytime soon?
I see the pop up key has been fixed, hurray, but the auto text still does not work for me. None of them will work and it was only after getting the galaxy nexus. I used it all the time. Any suggestions?
