Keyboard Selection in "Language & Keyboard Settings"
Fat Fingers
After selecting the Smart Keyboard as my keyboard (and turning off Android Keyboard) and then using the Droid for a while, I notice that the Android Keyboard gets turned back on (as evidenced by the green check mark next to it in the settings area). The Smart Keyboard Pro is still selected as on as well, buy why does the Android keyboard keep getting turned back on? And is this even a problem?
You mean you uncheck the android keyboard in the settings, and it gets checked by itself ? That's weird, I have no explanation for that ;)
Fat Fingers
Yes, that is what I mean. I don't see it causing any problems with the way the Smart Keyboard works (yet), but cannot say for sure.
