I really like Smart Keyboard Pro but the only thing annoying is that you have to lift your fingers when you press the ALT-key, for e.g. in Germany the "U" to get a "Ü".
Can you make the same way as other keyboards (incl. stock keyboard) that you can slide from the original key to the ALT-key not having to lift the finger and press
again? This removes the "smotheness" of typing in my eyes.
I thought this was not the case in the trial version but not sure. Or is that a setting which I did not find yet?
Thanks for considering.
Android rules
Android rules
