Spacebar and Sliding to Another Key
bradyonly
Not a big bug but if you hit the spacebar then slide your finger to another key and let go, it puts a space as well as the letter you let go on. So for example, if you hit the spacebar and then accidentally slide up to b and let go, it'll put a b right after the space and that kind of messes up the prediction for the next word because of that extra letter.
Edit
Version 1.8.0 Nexus One Cyanogen 5.0.3.1
that's because the spacebar is a repeatable key, so it's hit as soon as you press it (otherwise it could not be repeatable). As far as I know, all keyboards to this
bradyonly
Well the HTC IME Touch Input doesn't do it. The stock doesn't do it. Better keyboard doesn't do it. Out of the 5 keyboards I have, none of them except yours do it and they all repeat just fine.
Ah my mistake, the behaviour is indeed different (I am tired now...), I will have a look later
bradyonly
Thanks Cyril! You have an amazing keyboard none the less, keep up the awesome work.
