Greetings -
Am using A-2.2 and did a recent update of my SK-Pro. Unfortunately the update appears to have reset my "English (Dvorak)" keyboard to Qwerty. Same problem in both Portrait and Landscape modes. Neither "T9" nor "Compact Qwerty" are involved. I have double-checked that the "Smart Keyboard Pro Settings" for "Current Language" and "Language Selection Key" are indeed set to "English (Dvorak)" however all keyboards still show up as QWERTY in any apps I open. No "Gesture / Swipe" options are set to anything related to keyboard types or languages. I am using the "iPhone" skin and "Normal" portrait mode settings. This is on an HTC Droid Incredible w/o a physical keyboard. From within the Android 2.2 "Language & Keyboard" "Settings" window I have "Smart Keyboard Pro" checked however the Android "Touch Input" option on that page only shows a "Keyboard Types" option set of "Qwerty, Phone Keypad and Compact Qwerty"... "Qwerty" is checked and there is no option to uncheck it or to select Dvorak. Bottom line... after hours of work... I'm stumped. It worked fine before. What happened?
