Long press character without unity
keijun
I use both Korean and English.
The long press key function is GREAT!!
However when I press the top row (QWERTYUIOP), the position of the numbers are different.
When I press 'ㅂ' (same position with 'Q' in Eng keypad), '1' is on the right side of the 'ㅃ'.
However when I press 'ㅔ' (same position with 'P' in Eng keypad), '0' is on the left side of the 'ㅖ'.
It's not good.
So, please make this interface same.
I think right side is better.
(1~5 is on the right side and 9~0 is on the left side.)
maybe you feel it's not good, but it's impossible to change it. Indeed if you press ㅂ, 1 should be selected by default (unless you disabled the "korean numbers priority" option) so it must be on the left side (to be above the typed key), otherwise ㅂ would be the default selection. Same thing for ㅔ, as 0 is the default selection it must be on the right side.
