Landscape mode language and other issues, Xperia Mini Pro
christian_a_torres
Hello. I have the Xperia Mini Pro with a physical QWERTY keyboard. (Android 1.6 to be updated to 2.1 by the end of the month according to Sony Ericsson.) The only thing missing from Smart Keyboard is that I bought the phone in Sweden with the Swedish letters Ä, Ö, and Å. The Norwegian equivalent letters are Æ, Ø and Å. With the standard input method in landscape language Norwegian (see picture 1) tapping those Swedish letter in the physical keyboard would result in the correct Norwegian letters being shown on the screen since they have the same physical location. Is there any way of this happening in Smart Keyboard? The language has been set to Norwegian both in the phone and in Smart Keyboard.
Issue 1: Basically since Smart Keyboard is intercepting the physical keyboard is there a way to change the language while using the physical keyboard? Make Smartkeyboard ignore the default language of the physical keyboard?
Issue 2: Also this phone has a blue button (lower left corner) that works as a function (Fn) key Picture 4. Press once you can type in one number/character (picture 2). Press twice to hold the function and you can type in multiple numbers/characters (picture 3). Press thrice to return to normal keyboard (picture 1). Any way of implementing this icon?
External image (img811.imageshack.us) Picture 1 External image (img267.imageshack.us)]Picture 2 External image (img219.imageshack.us) Picture 3 External image (img524.imageshack.us) Picture 4
Issue 3: Tapping the Sym/áü button (lower right corner) would with the standard input method bring up the following menu
External image (img826.imageshack.us) External image (img339.imageshack.us) External image (img407.imageshack.us)
External image (img820.imageshack.us)External image (img718.imageshack.us) External image (img221.imageshack.us)
Any way of implementing this? Pressing this button with smartkeyboard brings up nothing..
Thanks in advance for your help :-) (Sorry for the wall of text and images, but i think it explains better than words :-))
I assume that you actually wanted smart keyboard pro to intercept the physical keyboard ("physical keyboard" option), otherwise you can just disable the option and all the problems will disappear ;)
So:
1) you can already change the language with the hard keyboard with shift + space, but hard key translation is currently only implemented for Russian and Korean, so it will have no effect if you set the language to Norwegian.
2)3) there is actually nothing to implement, the keyboard should just ignore those keys and forward them to the standard hard key handler. It's supposed to be already the case for the "SYM" key, but maybe it has a different key code on your phone. Same thing for the other function key. I guess the only way to progress on this is that I send you a debug version of the app, and you tell me the key codes for these keys.
Also, can you post a screenshot of the hard keyboard? I would like to see where are these Ä, Ö, and Å keys
christian_a_torres
With the "physical keyboard option " unticked the phone does not revert to the standard (ie sony ericsson) input method while using the physical keyboard if the input method has been selected as Smart keyboard during portrait mode. The lower language bar as seen in picture 1 (signalizing default input method) is gone and there is correctly no prediction from Smart Keyboard.
Hard key language change implementation (shift+space) does indeed not function when set to Norwegian, which is duly needed. The physical keyboard is sending Swedish letters and I would like for the phone to receive Norwegians. The Norwegian Æ is equal to the Ä key (see picture 4 lower right corner), the Norwegian Ø is equal to the Ö key (see picture 4 lower right corner) and the Swedish Å is the same as Norwegian Å as (see picture 4 lower right corner). So there is basically only 2 buttons that differ from the Norwegian and Swedish keyboard. Would be great if pressing these keys would result in the Norwegian letter popping up in the screen :D
Function key (blue) does function with Smart keyboard its just the icon that is missing. But this is no biggie tbh since smart Keyboard has a sort of different icon over the flashing cursor when using this blue function key. So its possible to distinguish where you are in the function realm.
The biggest concern though is the Sym/áü button. As it is using Smart Keyboard the Sym/áü button gets the same function as the blue function key. It would be great if the Sym/áü button would be forwarded to the same place as the default input method handler. I will help in any way I can. You may send the debug version and tell me what you need :-)
Thanks for quick response :D
christian_a_torres
Was wondering what the outcome of these issues are and how to resolve the them?
I have no time to work on these at the moment, but I will get back to you!
You can try the beta version here, and enable debug logs in the advanced settings.
Can you hit this "sym" key and check in your phone logs something like this: "D/SmartKeyboard( 278): keyCode: 36", and tell me the results?
(You can get your phone logs with "Log Collector")
christian_a_torres
Thanks for getting back to me :D I downloaded the beta apk and installed it along with log collector. Shut down the phone. The sequel of actions made by me are (maybe it makes it easier to follow the log):
Startup phone with debug logs enabled in advanced settings
Check to see if logs are cleared
Into Handcent sms (portrait mode) with Smartkeyboard set as the default input method and the original Sony Ericcson input method disabled. Physical Keyboard option in smartkeyboard unticked
New message
Pull out physical keyboard and go into landscape mode.
Press the symbol key followed by G to get the numer 5 displayed
Back to portrait mode and exit to phone setting and tick physical keyboard option in smartkeyboard
Into Handcent sms (portrait mode) with Smartkeyboard set as the default input method and the original Sony Ericcson input method disabled. Physical Keyboard option in smartkeyboard ticked
New message
Press the symbol key followed by G to get the numer 5 displayed. smartkeyboard suggestions working.
Back to portrait mode and exit to phone setting and enable default Sony Ericsson input method. Smartkeyboard disabled.
Into Handcent sms (portrait mode) with original Sony Ericcson set as the default input method and Smartkeyboard input method disabled.
New message
Press the symbol key to get the symbols page up
Press smiley face button
Exit message and extract log
Log is as following:
10-18 16:40:54.141 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie
10-18 16:40:54.141 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie: DONE
10-18 16:40:54.141 I/wpa_supplicant( 1218): WAPI wpa_supplicant_event_associnfo: (wapi) no wapi info element found in association request
10-18 16:40:54.141 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=4
10-18 16:40:54.141 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=4]
10-18 16:40:54.141 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATING ==> ASSOCIATED
10-18 16:40:54.141 I/wpa_supplicant( 1218): Associated with 00:1d:7e:ad:33:30
10-18 16:40:54.141 I/wpa_supplicant( 1218): WAPIDBG wpa_supplicant_event_assoc:
10-18 16:40:54.141 I/wpa_supplicant( 1218): WAPIDBG wapi_notify_assoc
10-18 16:40:54.141 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=7
10-18 16:40:54.141 I/wpa_supplicant( 1218): CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]
10-18 16:40:54.141 V/WifiMonitor( 1168): Event [Associated with 00:1d:7e:ad:33:30]
10-18 16:40:54.141 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=7]
10-18 16:40:54.141 V/WifiMonitor( 1168): Event [CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]]
10-18 16:40:54.141 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATED ==> COMPLETED
10-18 16:40:54.141 V/WifiStateTracker( 1168): New network state is CONNECTED
10-18 16:40:54.161 D/WifiStateTracker( 1168): DhcpHandler: DHCP request started
10-18 16:40:58.471 I/ActivityManager( 1168): Start proc com.tni.TasKiller for service com.tni.TasKiller/.TasKillerLauncher: pid=2009 uid=10084 gids={3003, 1015}
10-18 16:40:59.031 I/ActivityManager( 1168): Process com.curvefish.widgets.apnonoff (pid 1977) has died.
10-18 16:40:59.141 I/ActivityManager( 1168): Starting activity: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.LanguageSettings }
10-18 16:40:59.251 I/Customization Framework( 1309): No configuration file: /system/etc/customization/settings/com/android/settings/custom_settings.xml
10-18 16:41:00.151 D/SmartKeyboard( 1558): onFinishInput
10-18 16:41:00.151 D/SmartKeyboard( 1558): onStartInput
10-18 16:41:00.151 I/ActivityManager( 1168): Start proc com.levelup.beautifulwidgets for broadcast com.levelup.beautifulwidgets/.HomeWidget14: pid=2034 uid=10077 gids={3003, 3002, 3001, 1015}
10-18 16:41:00.161 V/WifiStateTracker( 1168): DhcpHandler: DHCP request succeeded
10-18 16:41:00.161 V/WifiStateTracker( 1168): IP configuration: ipaddr 192.168.1.108 gateway 192.168.1.1 netmask 255.255.255.0 dns1 84.208.20.110 dns2 84.208.20.111 DHCP server 192.168.1.1 lease 86400 seconds
10-18 16:41:00.191 I/ActivityManager( 1168): processNextBroadcast: waiting for ProcessRecord{306c71c0 2034:com.levelup.beautifulwidgets/10077}
10-18 16:41:00.191 D/WifiWatchdogService( 1168): (android.server.ServerThread) homer (00:1d:7e:ad:33:30) does not require the watchdog
10-18 16:41:00.201 I/ActivityManager( 1168): processNextBroadcast: waiting for ProcessRecord{306c71c0 2034:com.levelup.beautifulwidgets/10077}
10-18 16:41:00.291 D/GpsLocationProvider( 1168): updateNetworkState available
10-18 16:41:00.291 D/GpsLocationProvider( 1168): NetworkThread wait for 14065940ms
10-18 16:41:00.481 I/ActivityManager( 1168): Displayed activity com.android.settings/.LanguageSettings: 1342 ms (total 1342 ms)
10-18 16:41:00.971 D/NetworkLocationProvider( 1168): onDataConnectionStateChanged 1
10-18 16:41:00.981 D/GpsLocationProvider( 1168): state: DISCONNECTED apnName: internet reason: dataDisabled
10-18 16:41:02.071 I/GTalkService( 1306): [ServiceAutoStarter] --- start GTalk service ---
10-18 16:41:02.091 I/MediaUploader( 1500): No need to wake up
10-18 16:41:02.331 I/ActivityManager( 1168): Start proc com.curvefish.widgets.apnonoff for broadcast com.curvefish.widgets.apnonoff/.Widget: pid=2044 uid=10100 gids={3003, 1015}
10-18 16:41:02.341 I/ActivityManager( 1168): Process com.levelup.beautifulwidgets (pid 2034) has died.
10-18 16:41:02.561 I/ActivityManager( 1168): Stopping service: com.android.providers.downloads/.DownloadService
10-18 16:41:02.641 I/ActivityManager( 1168): Starting activity: Intent { act=android.intent.action.MAIN cmp=net.cdeguet.smartkeyboardpro/.Settings }
10-18 16:41:02.981 I/ActivityManager( 1168): Process com.curvefish.widgets.apnonoff (pid 2044) has died.
10-18 16:41:03.091 W/Resources( 1558): Converting to string: TypedValue{t=0x10/d=0x0 a=-1}
10-18 16:41:03.111 W/Resources( 1558): Converting to string: TypedValue{t=0x10/d=0x1 a=-1}
10-18 16:41:03.111 W/Resources( 1558): Converting to string: TypedValue{t=0x10/d=0x0 a=-1}
10-18 16:41:03.111 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:41:03.231 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@307262c0 (uid=1000 pid=1992)
10-18 16:41:03.291 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:41:03.291 W/IInputConnectionWrapper( 1992): showStatusIcon on inactive InputConnection
10-18 16:41:03.291 D/SmartKeyboard( 1558): onBindInput
10-18 16:41:03.291 D/SmartKeyboard( 1558): onStartInput
10-18 16:41:03.461 I/ActivityManager( 1168): Displayed activity net.cdeguet.smartkeyboardpro/.Settings: 734 ms (total 734 ms)
10-18 16:41:05.091 D/SmartKeyboard( 1558): onFinishInput
10-18 16:41:05.091 D/SmartKeyboard( 1558): onStartInput
10-18 16:41:08.001 I/ActivityManager( 1168): Process com.tni.TasKiller (pid 2009) has died.
10-18 16:41:08.701 D/GTalkService( 1306): [RosterMgr] roster not modified
10-18 16:41:09.011 D/GTalkService( 1306): [OtrMgr] OTR not modified
10-18 16:41:13.481 I/ActivityManager( 1168): Start proc com.tni.TasKiller for service com.tni.TasKiller/.TasKillerLauncher: pid=2052 uid=10084 gids={3003, 1015}
10-18 16:41:16.151 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:41:16.331 I/ActivityManager( 1168): Process com.tni.TasKiller (pid 2052) has died.
10-18 16:41:28.471 I/ActivityManager( 1168): Start proc com.tni.TasKiller for service com.tni.TasKiller/.TasKillerLauncher: pid=2071 uid=10084 gids={3003, 1015}
10-18 16:41:29.251 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:41:35.261 D/WifiService( 1168): ACTION_SCREEN_OFF
10-18 16:41:35.341 D/WifiService( 1168): setting ACTION_DEVICE_IDLE timer for 900000ms
10-18 16:41:38.611 I/FastDormancyManager( 1168): Fast Dormant executed. ExecuteCount:2 NonExecuteCount:95
10-18 16:42:00.528 I/wpa_supplicant( 1218): CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys
10-18 16:42:00.528 V/WifiMonitor( 1168): Event [CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys]
10-18 16:42:00.528 V/WifiStateTracker( 1168): New network state is DISCONNECTED
10-18 16:42:00.528 I/wpa_supplicant( 1218): WAPI wapi_notify_disassoc: received disassoc, reinit sm
10-18 16:42:00.528 I/wpa_supplicant( 1218): WAPI wapi_deinit_sm: deinit wapi sm
10-18 16:42:00.528 I/wpa_supplicant( 1218): WAPI wapi_init_sm: init wapi sm
10-18 16:42:00.528 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=0
10-18 16:42:00.528 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=0]
10-18 16:42:00.528 V/WifiStateTracker( 1168): Changing supplicant state: COMPLETED ==> DISCONNECTED
10-18 16:42:00.578 D/KeyguardViewMediator( 1168): wakeWhenReadyLocked(82)
10-18 16:42:00.628 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=2
10-18 16:42:00.628 E/wpa_supplicant( 1218): ERROR - wpa_driver_tista_private_send - (ioctl_cmd = 8021501, res = 1, errno = 11)
10-18 16:42:00.628 E/wpa_supplicant( 1218): ERROR - Failed to do tista scan!
10-18 16:42:00.628 W/wpa_supplicant( 1218): Failed to initiate AP scan.
10-18 16:42:00.628 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=2]
10-18 16:42:00.628 V/WifiStateTracker( 1168): Changing supplicant state: DISCONNECTED ==> SCANNING
10-18 16:42:00.638 I/ActivityManager( 1168): Start proc com.levelup.beautifulwidgets for broadcast com.levelup.beautifulwidgets/.HomeWidget: pid=2077 uid=10077 gids={3003, 3002, 3001, 1015}
10-18 16:42:00.638 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:42:00.668 D/KeyguardViewMediator( 1168): handleWakeWhenReady(82)
10-18 16:42:00.678 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:42:00.788 I/ActivityManager( 1168): processNextBroadcast: waiting for ProcessRecord{307be348 2077:com.levelup.beautifulwidgets/10077}
10-18 16:42:00.918 I/WindowManager( 1168): onOrientationChanged, rotation changed to 0
10-18 16:42:01.078 I/ActivityManager( 1168): Process com.facebook.katana (pid 1734) has died.
10-18 16:42:01.468 W/KeyCharacterMap( 1168): Can't open keycharmap file
10-18 16:42:01.468 W/KeyCharacterMap( 1168): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:42:01.468 W/KeyCharacterMap( 1168): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:42:01.468 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:42:01.488 W/InputManagerService( 1168): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@307fa8f0
10-18 16:42:01.498 D/SmartKeyboard( 1558): onFinishInput
10-18 16:42:01.498 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:01.738 D/WifiService( 1168): ACTION_SCREEN_ON
10-18 16:42:02.048 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:42:02.098 D/Beautiful Widgets( 2077): UserPresent
10-18 16:42:02.098 D/Beautiful Widgets( 2077): It has been less that 10 min since last weather refresh, do not refresh!
10-18 16:42:02.098 D/Beautiful Widgets( 2077): Screensaver mode: true
10-18 16:42:02.108 I/ActivityManager( 1168): Starting activity: Intent { act=com.levelup.beautifulwidgets.action.screensaver flg=0x10000000 cmp=com.levelup.beautifulwidgets/.ForecastActivity }
10-18 16:42:02.198 D/Beautiful Widgets( 2077): OnCreateForecast from widget
10-18 16:42:02.728 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:42:02.728 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@30710ff8 (uid=10107 pid=1558)
10-18 16:42:02.728 W/IInputConnectionWrapper( 1558): showStatusIcon on inactive InputConnection
10-18 16:42:02.728 D/SmartKeyboard( 1558): onBindInput
10-18 16:42:02.728 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:02.758 I/ActivityManager( 1168): Displayed activity com.levelup.beautifulwidgets/.ForecastActivity: 642 ms (total 642 ms)
10-18 16:42:05.768 I/ActivityManager( 1168): Process com.tni.TasKiller (pid 2071) has died.
10-18 16:42:05.868 W/Process ( 1168): Unable to open /proc/1734/status
10-18 16:42:05.898 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:42:05.898 D/SmartKeyboard( 1558): onBindInput
10-18 16:42:05.898 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:05.898 W/IInputConnectionWrapper( 2077): showStatusIcon on inactive InputConnection
10-18 16:42:06.828 D/KBD ( 1558): onInitializeInterface
10-18 16:42:08.533 D/WifiStateTracker( 1168): Deconfiguring interface and stopping DHCP
10-18 16:42:08.538 W/Smack/Packet( 1306): notify conn break (IOEx), close connection
10-18 16:42:08.538 D/Smack ( 1306): [XMPPConn] close connection, notifyClosed=false
10-18 16:42:09.218 D/SmartKeyboard( 1558): onFinishInput
10-18 16:42:09.218 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:09.608 D/NetworkLocationProvider( 1168): onDataConnectionStateChanged 1
10-18 16:42:09.628 I/GTalkService( 1306): [ServiceAutoStarter] --- start GTalk service ---
10-18 16:42:09.638 I/MediaUploader( 1500): No need to wake up
10-18 16:42:09.718 I/ActivityManager( 1168): Start proc com.curvefish.widgets.apnonoff for broadcast com.curvefish.widgets.apnonoff/.Widget: pid=2095 uid=10100 gids={3003, 1015}
10-18 16:42:09.798 D/GpsLocationProvider( 1168): updateNetworkState available
10-18 16:42:09.798 D/GpsLocationProvider( 1168): NetworkThread wait for 13996433ms
10-18 16:42:09.798 D/GpsLocationProvider( 1168): state: CONNECTING apnName: internet reason: null
10-18 16:42:10.918 D/SmartKeyboard( 1558): keyCode: 4
10-18 16:42:10.948 D/NetworkLocationProvider( 1168): onDataConnectionStateChanged 1
10-18 16:42:10.978 D/GpsLocationProvider( 1168): state: CONNECTED apnName: internet reason: null
10-18 16:42:11.048 I/GTalkService( 1306): [ServiceAutoStarter] --- start GTalk service ---
10-18 16:42:11.058 I/MediaUploader( 1500): No need to wake up
10-18 16:42:11.188 I/ActivityManager( 1168): Stopping service: com.sonyericsson.conversations/com.android.mms.transaction.TransactionService
10-18 16:42:11.258 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:42:11.258 D/SmartKeyboard( 1558): onBindInput
10-18 16:42:11.258 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:11.268 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@30710ff8 (uid=10107 pid=1558)
10-18 16:42:11.298 D/GpsLocationProvider( 1168): updateNetworkState available
10-18 16:42:11.298 D/GpsLocationProvider( 1168): NetworkThread wait for 13994930ms
10-18 16:42:11.348 I/ActivityManager( 1168): Stopping service: com.android.providers.downloads/.DownloadService
10-18 16:42:12.078 I/wpa_supplicant( 1218): CTRL-EVENT-SCAN-RESULTS Ready
10-18 16:42:12.078 I/wpa_supplicant( 1218): skip - no WPA/RSN/WAPI IE
10-18 16:42:12.078 I/wpa_supplicant( 1218): Trying to associate with 00:1d:7e:ad:33:30 (SSID='homer' freq=2 MHz)
10-18 16:42:12.078 I/wpa_supplicant( 1218): WAPIDBG wpa_supplicant_associate: disabling external mode
10-18 16:42:12.078 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie
10-18 16:42:12.078 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie: DONE
10-18 16:42:12.078 I/wpa_supplicant( 1218): IDAN: pairwise: 1 group: 1
10-18 16:42:12.078 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=3
10-18 16:42:12.078 V/WifiMonitor( 1168): Event [Trying to associate with 00:1d:7e:ad:33:30 (SSID='homer' freq=2 MHz)]
10-18 16:42:12.078 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=3]
10-18 16:42:12.088 V/WifiStateTracker( 1168): Changing supplicant state: SCANNING ==> ASSOCIATING
10-18 16:42:12.139 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie
10-18 16:42:12.139 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie: DONE
10-18 16:42:12.139 I/wpa_supplicant( 1218): WAPI wpa_supplicant_event_associnfo: (wapi) no wapi info element found in association request
10-18 16:42:12.139 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=4
10-18 16:42:12.139 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=4]
10-18 16:42:12.139 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATING ==> ASSOCIATED
10-18 16:42:12.148 I/wpa_supplicant( 1218): Associated with 00:1d:7e:ad:33:30
10-18 16:42:12.148 I/wpa_supplicant( 1218): WAPIDBG wpa_supplicant_event_assoc:
10-18 16:42:12.148 I/wpa_supplicant( 1218): WAPIDBG wapi_notify_assoc
10-18 16:42:12.148 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=7
10-18 16:42:12.148 I/wpa_supplicant( 1218): CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]
10-18 16:42:12.148 V/WifiMonitor( 1168): Event [Associated with 00:1d:7e:ad:33:30]
10-18 16:42:12.148 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=7]
10-18 16:42:12.148 V/WifiMonitor( 1168): Event [CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]]
10-18 16:42:12.148 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATED ==> COMPLETED
10-18 16:42:12.148 V/WifiStateTracker( 1168): New network state is CONNECTED
10-18 16:42:12.158 D/WifiStateTracker( 1168): DhcpHandler: DHCP request started
10-18 16:42:12.188 D/SmartKeyboard( 1558): keyCode: 4
10-18 16:42:12.188 W/KeyCharacterMap( 1992): Can't open keycharmap file
10-18 16:42:12.188 W/KeyCharacterMap( 1992): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:42:12.188 W/KeyCharacterMap( 1992): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:42:12.358 D/SmartKeyboard( 1558): onFinishInput
10-18 16:42:12.358 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:12.788 D/SmartKeyboard( 1558): keyCode: 4
10-18 16:42:12.888 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:42:12.888 D/SmartKeyboard( 1558): onBindInput
10-18 16:42:12.888 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:12.888 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@307262c0 (uid=1000 pid=1992)
10-18 16:42:12.888 W/IInputConnectionWrapper( 1992): showStatusIcon on inactive InputConnection
10-18 16:42:13.498 I/ActivityManager( 1168): Start proc com.tni.TasKiller for service com.tni.TasKiller/.TasKillerLauncher: pid=2112 uid=10084 gids={3003, 1015}
10-18 16:42:14.448 I/ActivityManager( 1168): Process com.levelup.beautifulwidgets (pid 2077) has died.
10-18 16:42:15.878 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:42:18.158 V/WifiStateTracker( 1168): DhcpHandler: DHCP request succeeded
10-18 16:42:18.168 V/WifiStateTracker( 1168): IP configuration: ipaddr 192.168.1.108 gateway 192.168.1.1 netmask 255.255.255.0 dns1 84.208.20.110 dns2 84.208.20.111 DHCP server 192.168.1.1 lease 86400 seconds
10-18 16:42:18.208 I/GTalkService( 1306): [ServiceAutoStarter] --- start GTalk service ---
10-18 16:42:18.238 I/MediaUploader( 1500): No need to wake up
10-18 16:42:18.318 D/WifiWatchdogService( 1168): (android.server.ServerThread) homer (00:1d:7e:ad:33:30) does not require the watchdog
10-18 16:42:18.498 I/ActivityManager( 1168): Stopping service: com.android.providers.downloads/.DownloadService
10-18 16:42:18.578 D/GpsLocationProvider( 1168): updateNetworkState available
10-18 16:42:18.578 D/GpsLocationProvider( 1168): NetworkThread wait for 13987647ms
10-18 16:42:19.338 D/NetworkLocationProvider( 1168): onDataConnectionStateChanged 1
10-18 16:42:19.348 D/GpsLocationProvider( 1168): state: DISCONNECTED apnName: internet reason: dataDisabled
10-18 16:42:29.288 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:42:30.958 D/GTalkService( 1306): [RosterMgr] roster not modified
10-18 16:42:31.228 D/GTalkService( 1306): [OtrMgr] OTR not modified
10-18 16:42:42.398 D/SmartKeyboard( 1558): keyCode: 82
10-18 16:42:42.398 W/KeyCharacterMap( 1693): Can't open keycharmap file
10-18 16:42:42.398 W/KeyCharacterMap( 1693): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:42:42.398 W/KeyCharacterMap( 1693): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:42:43.648 W/InputManagerService( 1168): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@307a0b80
10-18 16:42:43.968 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:42:44.428 I/ActivityManager( 1168): Starting activity: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 cmp=com.handcent.nextsms/com.handcent.sms.ui.ConversationExList }
10-18 16:42:44.698 D/sss ( 1590): 1287412964701
10-18 16:42:44.948 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:42:44.948 D/SmartKeyboard( 1558): onBindInput
10-18 16:42:44.948 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:44.948 W/IInputConnectionWrapper( 1693): showStatusIcon on inactive InputConnection
10-18 16:42:44.968 I/ActivityManager( 1168): Displayed activity com.handcent.nextsms/com.handcent.sms.ui.ConversationExList: 527 ms (total 527 ms)
10-18 16:42:46.258 I/ActivityManager( 1168): Starting activity: Intent { cmp=com.handcent.nextsms/com.handcent.sms.ui.ComposeMessageActivity }
10-18 16:42:46.568 D/SmartKeyboard( 1558): onFinishInput
10-18 16:42:46.568 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:46.761 I/ActivityManager( 1168): Displayed activity com.handcent.nextsms/com.handcent.sms.ui.ComposeMessageActivity: 494 ms (total 494 ms)
10-18 16:42:48.768 D/SmartKeyboard( 1558): onFinishInput
10-18 16:42:48.768 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:48.768 D/SmartKeyboard( 1558): onStartInputView
10-18 16:42:48.768 D/SmartKeyboard( 1558): Called from package com.handcent.nextsms
10-18 16:42:49.810 I/WindowManager( 1168): Setting rotation to 1, animFlags=1
10-18 16:42:49.810 I/WindowManager( 1168): Config changed: { scale=1.0 imsi=0/0 loc=nb_NO touch=3 keys=2/1/1 nav=1 orien=2 layout=17}
10-18 16:42:49.988 D/KBD ( 1558): onInitializeInterface
10-18 16:42:50.038 D/StatusBar( 1168): updateResources
10-18 16:42:50.068 D/JorteService( 1612): Thread idling wakeup
10-18 16:42:50.088 D/JorteService( 1612): Thread idling wait next
10-18 16:42:50.128 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:50.178 D/SmartKeyboard( 1558): hideWindow java.lang.Exception
10-18 16:42:50.178 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.hideWindow(Unknown Source)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.setCandidatesViewShown(InputMethodService.java:1001)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.setCandidatesViewShown(Unknown Source)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.onStartInput(Unknown Source)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.doStartInput(InputMethodService.java:1434)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.onConfigurationChanged(InputMethodService.java:650)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.onConfigurationChanged(Unknown Source)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.app.ActivityThread.performConfigurationChanged(ActivityThread.java:3612)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.app.ActivityThread.handleConfigurationChanged(ActivityThread.java:3678)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1866)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.os.Handler.dispatchMessage(Handler.java:99)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.os.Looper.loop(Looper.java:123)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.app.ActivityThread.main(ActivityThread.java:4232)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invokeNative(Native Method)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invoke(Method.java:521)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:799)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at dalvik.system.NativeStart.main(Native Method)
10-18 16:42:50.178 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.onConfigurationChanged(InputMethodService.java:663)
10-18 16:42:50.178 D/SmartKeyboard( 1558): onFinishInput
10-18 16:42:50.178 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:50.258 I/ActivityManager( 1168): Start proc com.levelup.beautifulwidgets for broadcast com.levelup.beautifulwidgets/.HomeWidget: pid=2143 uid=10077 gids={3003, 3002, 3001, 1015}
10-18 16:42:50.668 D/Beautiful Widgets( 2143): UserPresent
10-18 16:42:50.668 D/Beautiful Widgets( 2143): It has been less that 10 min since last weather refresh, do not refresh!
10-18 16:42:50.668 D/Beautiful Widgets( 2143): Screensaver mode: true
10-18 16:42:50.678 I/ActivityManager( 1168): Starting activity: Intent { act=com.levelup.beautifulwidgets.action.screensaver flg=0x10000000 cmp=com.levelup.beautifulwidgets/.ForecastActivity }
10-18 16:42:50.978 D/Beautiful Widgets( 2143): OnCreateForecast from widget
10-18 16:42:51.018 I/WindowManager( 1168): onOrientationChanged, rotation changed to 1
10-18 16:42:52.368 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:42:52.378 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@303f2b20 (uid=10076 pid=1590)
10-18 16:42:52.388 D/SmartKeyboard( 1558): hideWindow java.lang.Exception
10-18 16:42:52.388 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.hideWindow(Unknown Source)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService$InputMethodImpl.hideSoftInput(InputMethodService.java:371)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at android.inputmethodservice.IInputMethodWrapper.executeMessage(IInputMethodWrapper.java:151)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at com.android.internal.os.HandlerCaller$MyHandler.handleMessage(HandlerCaller.java:45)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at android.os.Handler.dispatchMessage(Handler.java:99)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at android.os.Looper.loop(Looper.java:123)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at android.app.ActivityThread.main(ActivityThread.java:4232)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invokeNative(Native Method)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invoke(Method.java:521)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:799)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557)
10-18 16:42:52.388 D/SmartKeyboard( 1558): at dalvik.system.NativeStart.main(Native Method)
10-18 16:42:52.388 D/SmartKeyboard( 1558): onBindInput
10-18 16:42:52.388 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:52.388 W/IInputConnectionWrapper( 1590): showStatusIcon on inactive InputConnection
10-18 16:42:52.418 I/ActivityManager( 1168): Displayed activity com.levelup.beautifulwidgets/.ForecastActivity: 1735 ms (total 1735 ms)
10-18 16:42:52.558 I/ActivityManager( 1168): Process com.android.settings (pid 1992) has died.
10-18 16:42:52.658 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:42:52.658 D/SmartKeyboard( 1558): onBindInput
10-18 16:42:52.658 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:52.678 W/IInputConnectionWrapper( 2143): showStatusIcon on inactive InputConnection
10-18 16:42:53.518 D/SmartKeyboard( 1558): onFinishInput
10-18 16:42:53.518 D/SmartKeyboard( 1558): onStartInput
10-18 16:42:57.408 W/KeyCharacterMap( 1590): Can't open keycharmap file
10-18 16:42:57.408 W/KeyCharacterMap( 1590): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:42:57.408 W/KeyCharacterMap( 1590): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:42:58.608 D/SmartKeyboard( 1558): keyCode: 35
10-18 16:42:59.338 D/SmartKeyboard( 1558): onCreateCandidatesView
10-18 16:42:59.828 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:43:13.718 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:43:14.378 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:43:29.318 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:43:29.448 D/WifiService( 1168): ACTION_SCREEN_OFF
10-18 16:43:29.508 D/WifiService( 1168): setting ACTION_DEVICE_IDLE timer for 900000ms
10-18 16:43:30.779 I/WindowManager( 1168): Setting rotation to 0, animFlags=1
10-18 16:43:30.779 I/WindowManager( 1168): Config changed: { scale=1.0 imsi=0/0 loc=nb_NO touch=3 keys=2/1/2 nav=1 orien=1 layout=17}
10-18 16:43:30.818 W/IInputConnectionWrapper( 1590): commitText on inactive InputConnection
10-18 16:43:31.108 D/KBD ( 1558): onInitializeInterface
10-18 16:43:31.158 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:31.168 D/SmartKeyboard( 1558): hideWindow java.lang.Exception
10-18 16:43:31.168 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.hideWindow(Unknown Source)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.setCandidatesViewShown(InputMethodService.java:1001)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.setCandidatesViewShown(Unknown Source)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.onStartInput(Unknown Source)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.doStartInput(InputMethodService.java:1434)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.onConfigurationChanged(InputMethodService.java:650)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.onConfigurationChanged(Unknown Source)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.app.ActivityThread.performConfigurationChanged(ActivityThread.java:3612)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.app.ActivityThread.handleConfigurationChanged(ActivityThread.java:3678)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1866)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.os.Handler.dispatchMessage(Handler.java:99)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.os.Looper.loop(Looper.java:123)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at android.app.ActivityThread.main(ActivityThread.java:4232)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invokeNative(Native Method)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invoke(Method.java:521)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:799)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557)
10-18 16:43:31.168 D/SmartKeyboard( 1558): at dalvik.system.NativeStart.main(Native Method)
10-18 16:43:31.178 D/SmartKeyboard( 1558): hideWindow java.lang.Exception
10-18 16:43:31.178 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.hideWindow(Unknown Source)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService.onConfigurationChanged(InputMethodService.java:671)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.onConfigurationChanged(Unknown Source)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at android.app.ActivityThread.performConfigurationChanged(ActivityThread.java:3612)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at android.app.ActivityThread.handleConfigurationChanged(ActivityThread.java:3678)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1866)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at android.os.Handler.dispatchMessage(Handler.java:99)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at android.os.Looper.loop(Looper.java:123)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at android.app.ActivityThread.main(ActivityThread.java:4232)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invokeNative(Native Method)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invoke(Method.java:521)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:799)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557)
10-18 16:43:31.178 D/SmartKeyboard( 1558): at dalvik.system.NativeStart.main(Native Method)
10-18 16:43:31.178 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:31.178 D/SmartKeyboard( 1558): onCreateInputView
10-18 16:43:31.198 D/JorteService( 1612): Thread idling wakeup
10-18 16:43:31.218 D/JorteService( 1612): Thread idling wait next
10-18 16:43:31.228 D/StatusBar( 1168): updateResources
10-18 16:43:31.248 D/SmartKeyboard( 1558): onCreateCandidatesView
10-18 16:43:31.268 W/IInputConnectionWrapper( 1590): showStatusIcon on inactive InputConnection
10-18 16:43:31.298 D/SmartKeyboard( 1558): onStartInputView
10-18 16:43:31.298 D/SmartKeyboard( 1558): Called from package com.handcent.nextsms
10-18 16:43:31.298 W/IInputConnectionWrapper( 1590): getCursorCapsMode on inactive InputConnection
10-18 16:43:31.308 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:31.308 D/SmartKeyboard( 1558): onStartInputView
10-18 16:43:31.308 D/SmartKeyboard( 1558): Called from package com.handcent.nextsms
10-18 16:43:31.308 W/IInputConnectionWrapper( 1590): getCursorCapsMode on inactive InputConnection
10-18 16:43:33.279 D/KeyguardViewMediator( 1168): wakeWhenReadyLocked(82)
10-18 16:43:33.279 D/KeyguardViewMediator( 1168): handleWakeWhenReady(82)
10-18 16:43:33.288 I/FastDormancyManager( 1168): Fast Dormant executed. ExecuteCount:3 NonExecuteCount:172
10-18 16:43:33.288 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:43:33.378 D/WifiService( 1168): ACTION_SCREEN_ON
10-18 16:43:33.648 I/WindowManager( 1168): onOrientationChanged, rotation changed to 0
10-18 16:43:33.658 W/KeyCharacterMap( 1168): Can't open keycharmap file
10-18 16:43:33.658 W/KeyCharacterMap( 1168): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:43:33.658 W/KeyCharacterMap( 1168): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:43:33.658 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:43:33.758 D/NetworkLocationProvider( 1168): onCellLocationChanged [2030,3422]
10-18 16:43:33.788 D/SmartKeyboard( 1558): onFinishInput
10-18 16:43:33.788 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:33.788 D/SmartKeyboard( 1558): onStartInputView
10-18 16:43:33.788 D/SmartKeyboard( 1558): Called from package com.handcent.nextsms
10-18 16:43:33.788 W/InputManagerService( 1168): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@305c26c8
10-18 16:43:33.868 D/Beautiful Widgets( 2143): UserPresent
10-18 16:43:33.868 D/Beautiful Widgets( 2143): It has been less that 10 min since last weather refresh, do not refresh!
10-18 16:43:33.868 D/Beautiful Widgets( 2143): Screensaver mode: true
10-18 16:43:33.868 I/ActivityManager( 1168): Starting activity: Intent { act=com.levelup.beautifulwidgets.action.screensaver flg=0x10000000 cmp=com.levelup.beautifulwidgets/.ForecastActivity }
10-18 16:43:33.938 D/Beautiful Widgets( 2143): OnCreateForecast from widget
10-18 16:43:34.458 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:43:34.458 D/SmartKeyboard( 1558): onBindInput
10-18 16:43:34.458 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:34.458 D/SmartKeyboard( 1558): onStartInputView
10-18 16:43:34.458 D/SmartKeyboard( 1558): Called from package com.levelup.beautifulwidgets
10-18 16:43:34.468 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@303f2b20 (uid=10076 pid=1590)
10-18 16:43:34.468 W/IInputConnectionWrapper( 1590): showStatusIcon on inactive InputConnection
10-18 16:43:34.538 I/ActivityManager( 1168): Displayed activity com.levelup.beautifulwidgets/.ForecastActivity: 663 ms (total 663 ms)
10-18 16:43:34.598 D/SmartKeyboard( 1558): hideWindow java.lang.Exception
10-18 16:43:34.598 D/SmartKeyboard( 1558): at net.cdeguet.smartkeyboardpro.SmartKeyboard.hideWindow(Unknown Source)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at android.inputmethodservice.InputMethodService$InputMethodImpl.hideSoftInput(InputMethodService.java:371)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at android.inputmethodservice.IInputMethodWrapper.executeMessage(IInputMethodWrapper.java:151)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at com.android.internal.os.HandlerCaller$MyHandler.handleMessage(HandlerCaller.java:45)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at android.os.Handler.dispatchMessage(Handler.java:99)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at android.os.Looper.loop(Looper.java:123)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at android.app.ActivityThread.main(ActivityThread.java:4232)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invokeNative(Native Method)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at java.lang.reflect.Method.invoke(Method.java:521)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:799)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557)
10-18 16:43:34.598 D/SmartKeyboard( 1558): at dalvik.system.NativeStart.main(Native Method)
10-18 16:43:34.768 D/SmartKeyboard( 1558): keyCode: 4
10-18 16:43:34.780 W/KeyCharacterMap( 2143): Can't open keycharmap file
10-18 16:43:34.780 W/KeyCharacterMap( 2143): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:43:34.780 W/KeyCharacterMap( 2143): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:43:34.818 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:43:34.818 D/SmartKeyboard( 1558): onBindInput
10-18 16:43:34.818 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:34.818 W/IInputConnectionWrapper( 2143): showStatusIcon on inactive InputConnection
10-18 16:43:35.938 D/SmartKeyboard( 1558): keyCode: 4
10-18 16:43:38.818 D/SmartKeyboard( 1558): onFinishInput
10-18 16:43:38.818 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:39.629 D/SmartKeyboard( 1558): keyCode: 4
10-18 16:43:39.708 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:43:39.708 D/SmartKeyboard( 1558): onBindInput
10-18 16:43:39.708 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:39.708 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@303f2b20 (uid=10076 pid=1590)
10-18 16:43:39.708 W/IInputConnectionWrapper( 1590): showStatusIcon on inactive InputConnection
10-18 16:43:40.828 D/SmartKeyboard( 1558): keyCode: 82
10-18 16:43:41.978 I/ActivityManager( 1168): Starting activity: Intent { act=android.settings.SETTINGS flg=0x10200000 cmp=com.android.settings/.Settings }
10-18 16:43:42.238 I/ActivityManager( 1168): Start proc com.android.settings for activity com.android.settings/.Settings: pid=2152 uid=1000 gids={3003, 3002, 3001, 3007, 3008}
10-18 16:43:42.248 W/InputManagerService( 1168): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@305de7d8
10-18 16:43:44.508 I/ActivityManager( 1168): Process com.levelup.beautifulwidgets (pid 2143) has died.
10-18 16:43:44.628 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:43:44.628 D/SmartKeyboard( 1558): onBindInput
10-18 16:43:44.628 D/SmartKeyboard( 1558): onStartInput
10-18 16:43:44.638 W/IInputConnectionWrapper( 1693): showStatusIcon on inactive InputConnection
10-18 16:43:44.848 I/ActivityManager( 1168): Displayed activity com.android.settings/.Settings: 2835 ms (total 2835 ms)
10-18 16:43:45.008 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:43:53.758 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:43:59.368 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:44:00.058 I/ActivityManager( 1168): Start proc com.levelup.beautifulwidgets for broadcast com.levelup.beautifulwidgets/.HomeWidget14: pid=2158 uid=10077 gids={3003, 3002, 3001, 1015}
10-18 16:44:03.748 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:44:12.198 D/WifiService( 1168): ACTION_SCREEN_OFF
10-18 16:44:12.248 D/WifiService( 1168): setting ACTION_DEVICE_IDLE timer for 900000ms
10-18 16:44:58.540 I/wpa_supplicant( 1218): CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys
10-18 16:44:58.540 V/WifiMonitor( 1168): Event [CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys]
10-18 16:44:58.540 I/wpa_supplicant( 1218): WAPI wapi_notify_disassoc: received disassoc, reinit sm
10-18 16:44:58.540 I/wpa_supplicant( 1218): WAPI wapi_deinit_sm: deinit wapi sm
10-18 16:44:58.550 I/wpa_supplicant( 1218): WAPI wapi_init_sm: init wapi sm
10-18 16:44:58.550 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=0
10-18 16:44:58.550 E/wpa_supplicant( 1218): ERROR - wpa_driver_tista_private_send - (ioctl_cmd = 810a22, res = 1, errno = 11)
10-18 16:44:58.550 E/wpa_supplicant( 1218): ERROR - Failed to get rssi level
10-18 16:44:58.550 V/WifiStateTracker( 1168): New network state is DISCONNECTED
10-18 16:44:58.550 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=0]
10-18 16:44:58.550 V/WifiStateTracker( 1168): Changing supplicant state: COMPLETED ==> DISCONNECTED
10-18 16:44:58.550 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:44:58.560 D/KeyguardViewMediator( 1168): wakeWhenReadyLocked(82)
10-18 16:44:58.560 D/KeyguardViewMediator( 1168): handleWakeWhenReady(82)
10-18 16:44:58.610 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:44:58.640 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=2
10-18 16:44:58.640 E/wpa_supplicant( 1218): ERROR - wpa_driver_tista_private_send - (ioctl_cmd = 8021501, res = 1, errno = 11)
10-18 16:44:58.640 E/wpa_supplicant( 1218): ERROR - Failed to do tista scan!
10-18 16:44:58.640 W/wpa_supplicant( 1218): Failed to initiate AP scan.
10-18 16:44:58.640 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=2]
10-18 16:44:58.640 V/WifiStateTracker( 1168): Changing supplicant state: DISCONNECTED ==> SCANNING
10-18 16:44:58.670 D/NetworkLocationProvider( 1168): onCellLocationChanged [2030,3423]
10-18 16:44:58.840 D/WifiService( 1168): ACTION_SCREEN_ON
10-18 16:44:58.910 I/WindowManager( 1168): onOrientationChanged, rotation changed to 0
10-18 16:44:59.310 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:44:59.466 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:44:59.500 W/InputManagerService( 1168): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@30702898
10-18 16:44:59.510 D/SmartKeyboard( 1558): onFinishInput
10-18 16:44:59.510 D/SmartKeyboard( 1558): onStartInput
10-18 16:44:59.640 D/Beautiful Widgets( 2158): UserPresent
10-18 16:44:59.640 D/Beautiful Widgets( 2158): It has been less that 10 min since last weather refresh, do not refresh!
10-18 16:44:59.640 D/Beautiful Widgets( 2158): Screensaver mode: true
10-18 16:44:59.640 I/ActivityManager( 1168): Starting activity: Intent { act=com.levelup.beautifulwidgets.action.screensaver flg=0x10000000 cmp=com.levelup.beautifulwidgets/.ForecastActivity }
10-18 16:44:59.720 D/Beautiful Widgets( 2158): OnCreateForecast from widget
10-18 16:44:59.820 W/KeyCharacterMap( 2158): Can't open keycharmap file
10-18 16:44:59.820 W/KeyCharacterMap( 2158): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:44:59.820 W/KeyCharacterMap( 2158): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:45:00.310 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@30760c98 (uid=10077 pid=2158)
10-18 16:45:00.310 W/InputManagerService( 1168): Client not active, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@30812470
10-18 16:45:00.410 I/ActivityManager( 1168): Displayed activity com.levelup.beautifulwidgets/.ForecastActivity: 761 ms (total 761 ms)
10-18 16:45:02.830 W/WindowManager( 1168): No window to dispatch pointer action 1
10-18 16:45:06.550 D/WifiStateTracker( 1168): Deconfiguring interface and stopping DHCP
10-18 16:45:06.560 W/Smack/Packet( 1306): notify conn break (IOEx), close connection
10-18 16:45:06.560 D/Smack ( 1306): [XMPPConn] close connection, notifyClosed=false
10-18 16:45:07.600 I/GTalkService( 1306): [ServiceAutoStarter] --- start GTalk service ---
10-18 16:45:07.610 I/MediaUploader( 1500): No need to wake up
10-18 16:45:07.960 D/GpsLocationProvider( 1168): updateNetworkState available
10-18 16:45:07.960 D/GpsLocationProvider( 1168): NetworkThread wait for 13818271ms
10-18 16:45:07.960 D/NetworkLocationProvider( 1168): onDataConnectionStateChanged 1
10-18 16:45:08.000 D/GpsLocationProvider( 1168): state: CONNECTING apnName: internet reason: null
10-18 16:45:08.140 I/ActivityManager( 1168): Starting activity: Intent { act=android.intent.action.MAIN cmp=com.android.settings/.LanguageSettings }
10-18 16:45:08.180 I/Customization Framework( 1309): No configuration file: /system/etc/customization/settings/com/android/settings/custom_settings.xml
10-18 16:45:08.400 D/SmartKeyboard( 1558): onFinishInput
10-18 16:45:08.400 D/SmartKeyboard( 1558): onStartInput
10-18 16:45:08.616 I/ActivityManager( 1168): Displayed activity com.android.settings/.LanguageSettings: 472 ms (total 472 ms)
10-18 16:45:08.910 D/NetworkLocationProvider( 1168): onDataConnectionStateChanged 1
10-18 16:45:09.030 D/GpsLocationProvider( 1168): state: CONNECTED apnName: internet reason: null
10-18 16:45:09.120 I/ActivityManager( 1168): Stopping service: com.sonyericsson.conversations/com.android.mms.transaction.TransactionService
10-18 16:45:09.200 D/GpsLocationProvider( 1168): updateNetworkState available
10-18 16:45:09.200 D/GpsLocationProvider( 1168): NetworkThread wait for 13817026ms
10-18 16:45:09.250 I/GTalkService( 1306): [ServiceAutoStarter] --- start GTalk service ---
10-18 16:45:09.260 I/MediaUploader( 1500): No need to wake up
10-18 16:45:09.340 I/ActivityManager( 1168): Stopping service: com.android.providers.downloads/.DownloadService
10-18 16:45:10.090 I/wpa_supplicant( 1218): CTRL-EVENT-SCAN-RESULTS Ready
10-18 16:45:10.090 I/wpa_supplicant( 1218): skip - no WPA/RSN/WAPI IE
10-18 16:45:10.090 I/wpa_supplicant( 1218): Trying to associate with 00:1d:7e:ad:33:30 (SSID='homer' freq=2 MHz)
10-18 16:45:10.090 I/wpa_supplicant( 1218): WAPIDBG wpa_supplicant_associate: disabling external mode
10-18 16:45:10.090 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie
10-18 16:45:10.090 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie: DONE
10-18 16:45:10.090 I/wpa_supplicant( 1218): IDAN: pairwise: 1 group: 1
10-18 16:45:10.090 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=3
10-18 16:45:10.090 V/WifiMonitor( 1168): Event [Trying to associate with 00:1d:7e:ad:33:30 (SSID='homer' freq=2 MHz)]
10-18 16:45:10.090 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=3]
10-18 16:45:10.100 V/WifiStateTracker( 1168): Changing supplicant state: SCANNING ==> ASSOCIATING
10-18 16:45:10.140 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie
10-18 16:45:10.140 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie: DONE
10-18 16:45:10.140 I/wpa_supplicant( 1218): WAPI wpa_supplicant_event_associnfo: (wapi) no wapi info element found in association request
10-18 16:45:10.140 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=4
10-18 16:45:10.140 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=4]
10-18 16:45:10.140 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATING ==> ASSOCIATED
10-18 16:45:10.140 I/wpa_supplicant( 1218): Associated with 00:1d:7e:ad:33:30
10-18 16:45:10.140 I/wpa_supplicant( 1218): WAPIDBG wpa_supplicant_event_assoc:
10-18 16:45:10.140 I/wpa_supplicant( 1218): WAPIDBG wapi_notify_assoc
10-18 16:45:10.140 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=7
10-18 16:45:10.140 I/wpa_supplicant( 1218): CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]
10-18 16:45:10.140 V/WifiMonitor( 1168): Event [Associated with 00:1d:7e:ad:33:30]
10-18 16:45:10.140 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=7]
10-18 16:45:10.140 V/WifiMonitor( 1168): Event [CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]]
10-18 16:45:10.140 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATED ==> COMPLETED
10-18 16:45:10.140 V/WifiStateTracker( 1168): New network state is CONNECTED
10-18 16:45:10.150 D/WifiStateTracker( 1168): DhcpHandler: DHCP request started
10-18 16:45:14.050 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:45:17.160 V/WifiStateTracker( 1168): DhcpHandler: DHCP request succeeded
10-18 16:45:17.160 V/WifiStateTracker( 1168): IP configuration: ipaddr 192.168.1.108 gateway 192.168.1.1 netmask 255.255.255.0 dns1 84.208.20.110 dns2 84.208.20.111 DHCP server 192.168.1.1 lease 86400 seconds
10-18 16:45:17.230 I/GTalkService( 1306): [ServiceAutoStarter] --- start GTalk service ---
10-18 16:45:17.250 I/MediaUploader( 1500): No need to wake up
10-18 16:45:17.310 D/WifiWatchdogService( 1168): (android.server.ServerThread) homer (00:1d:7e:ad:33:30) does not require the watchdog
10-18 16:45:17.480 D/GpsLocationProvider( 1168): updateNetworkState available
10-18 16:45:17.480 D/GpsLocationProvider( 1168): NetworkThread wait for 13808754ms
10-18 16:45:17.580 I/ActivityManager( 1168): Stopping service: com.android.providers.downloads/.DownloadService
10-18 16:45:17.870 D/NetworkLocationProvider( 1168): onDataConnectionStateChanged 1
10-18 16:45:17.890 D/GpsLocationProvider( 1168): state: DISCONNECTED apnName: internet reason: dataDisabled
10-18 16:45:29.330 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:45:34.850 D/GTalkService( 1306): [RosterMgr] roster not modified
10-18 16:45:34.980 D/GTalkService( 1306): [OtrMgr] OTR not modified
10-18 16:45:43.900 D/SmartKeyboard( 1558): onUnbindInput
10-18 16:45:43.900 I/ActivityManager( 1168): Stopping service: net.cdeguet.smartkeyboardpro/.SmartKeyboard
10-18 16:45:43.960 I/ActivityManager( 1168): Start proc com.sonyericsson.android.textinput for service com.sonyericsson.android.textinput/.glue.InputMethodServiceGlue: pid=2213 uid=10066 gids={}
10-18 16:45:44.010 D/WifiService( 1168): ACTION_SCREEN_OFF
10-18 16:45:44.030 D/WifiService( 1168): setting ACTION_DEVICE_IDLE timer for 900000ms
christian_a_torres
10-18 16:45:44.560 I/ActivityManager( 1168): Process com.levelup.beautifulwidgets (pid 2158) has died.
10-18 16:45:44.790 W/IInputConnectionWrapper( 2152): showStatusIcon on inactive InputConnection
10-18 16:45:44.930 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:45:45.100 E/ZiEngine( 2213): OnLoad
10-18 16:45:46.520 D/NetworkLocationProvider( 1168): onCellLocationChanged [2030,3411]
10-18 16:45:47.060 I/ActivityManager( 1168): Process com.tni.TasKiller (pid 2112) has died.
10-18 16:45:47.590 I/FastDormancyManager( 1168): Fast Dormant executed. ExecuteCount:4 NonExecuteCount:206
10-18 16:45:49.527 I/wpa_supplicant( 1218): CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys
10-18 16:45:49.527 I/wpa_supplicant( 1218): WAPI wapi_notify_disassoc: received disassoc, reinit sm
10-18 16:45:49.527 I/wpa_supplicant( 1218): WAPI wapi_deinit_sm: deinit wapi sm
10-18 16:45:49.527 I/wpa_supplicant( 1218): WAPI wapi_init_sm: init wapi sm
10-18 16:45:49.527 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=0
10-18 16:45:49.527 V/WifiMonitor( 1168): Event [CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys]
10-18 16:45:49.527 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=0]
10-18 16:45:49.537 V/WifiStateTracker( 1168): New network state is DISCONNECTED
10-18 16:45:49.537 V/WifiStateTracker( 1168): Changing supplicant state: COMPLETED ==> DISCONNECTED
10-18 16:45:49.567 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:45:49.617 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=2
10-18 16:45:49.617 E/wpa_supplicant( 1218): ERROR - wpa_driver_tista_private_send - (ioctl_cmd = 8021501, res = 1, errno = 11)
10-18 16:45:49.617 E/wpa_supplicant( 1218): ERROR - Failed to do tista scan!
10-18 16:45:49.617 W/wpa_supplicant( 1218): Failed to initiate AP scan.
10-18 16:45:49.617 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=2]
10-18 16:45:49.617 V/WifiStateTracker( 1168): Changing supplicant state: DISCONNECTED ==> SCANNING
10-18 16:47:17.571 D/KeyguardViewMediator( 1168): wakeWhenReadyLocked(82)
10-18 16:47:17.571 D/KeyguardViewMediator( 1168): handleWakeWhenReady(82)
10-18 16:47:17.621 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:47:17.881 I/ActivityManager( 1168): Start proc com.tni.TasKiller for service com.tni.TasKiller/.TasKillerLauncher: pid=2229 uid=10084 gids={3003, 1015}
10-18 16:47:17.911 D/NetworkLocationProvider( 1168): onCellLocationChanged [2030,3422]
10-18 16:47:17.941 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:47:18.161 I/WindowManager( 1168): onOrientationChanged, rotation changed to 0
10-18 16:47:18.191 I/ActivityManager( 1168): Start proc com.levelup.beautifulwidgets for broadcast com.levelup.beautifulwidgets/.HomeWidget: pid=2235 uid=10077 gids={3003, 3002, 3001, 1015}
10-18 16:47:18.721 I/ActivityManager( 1168): Process com.curvefish.widgets.apnonoff (pid 2095) has died.
10-18 16:47:18.841 W/KeyCharacterMap( 1168): Can't open keycharmap file
10-18 16:47:18.841 W/KeyCharacterMap( 1168): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:47:18.841 W/KeyCharacterMap( 1168): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:47:18.841 D/KeyguardViewMediator( 1168): pokeWakelock(5000)
10-18 16:47:18.871 W/InputManagerService( 1168): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@304b1e88
10-18 16:47:19.121 D/WifiService( 1168): ACTION_SCREEN_ON
10-18 16:47:19.471 D/Beautiful Widgets( 2235): UserPresent
10-18 16:47:19.471 D/Beautiful Widgets( 2235): It has been less that 10 min since last weather refresh, do not refresh!
10-18 16:47:19.471 D/Beautiful Widgets( 2235): Screensaver mode: true
10-18 16:47:19.501 I/ActivityManager( 1168): Starting activity: Intent { act=com.levelup.beautifulwidgets.action.screensaver flg=0x10000000 cmp=com.levelup.beautifulwidgets/.ForecastActivity }
10-18 16:47:19.731 I/wpa_supplicant( 1218): CTRL-EVENT-SCAN-RESULTS Ready
10-18 16:47:19.731 I/wpa_supplicant( 1218): skip - no WPA/RSN/WAPI IE
10-18 16:47:19.731 I/wpa_supplicant( 1218): Trying to associate with 00:1d:7e:ad:33:30 (SSID='homer' freq=2 MHz)
10-18 16:47:19.731 I/wpa_supplicant( 1218): WAPIDBG wpa_supplicant_associate: disabling external mode
10-18 16:47:19.731 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie
10-18 16:47:19.731 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie: DONE
10-18 16:47:19.731 I/wpa_supplicant( 1218): IDAN: pairwise: 1 group: 1
10-18 16:47:19.731 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=3
10-18 16:47:19.741 V/WifiMonitor( 1168): Event [Trying to associate with 00:1d:7e:ad:33:30 (SSID='homer' freq=2 MHz)]
10-18 16:47:19.741 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=3]
10-18 16:47:19.741 V/WifiStateTracker( 1168): Changing supplicant state: SCANNING ==> ASSOCIATING
10-18 16:47:19.781 D/Beautiful Widgets( 2235): OnCreateForecast from widget
10-18 16:47:19.791 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie
10-18 16:47:19.791 I/wpa_supplicant( 1218): WAPIDBG wapi_set_assoc_ie: DONE
10-18 16:47:19.791 I/wpa_supplicant( 1218): WAPI wpa_supplicant_event_associnfo: (wapi) no wapi info element found in association request
10-18 16:47:19.791 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=4
10-18 16:47:19.791 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=4]
10-18 16:47:19.791 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATING ==> ASSOCIATED
10-18 16:47:19.801 I/wpa_supplicant( 1218): Associated with 00:1d:7e:ad:33:30
10-18 16:47:19.801 I/wpa_supplicant( 1218): WAPIDBG wpa_supplicant_event_assoc:
10-18 16:47:19.801 I/wpa_supplicant( 1218): WAPIDBG wapi_notify_assoc
10-18 16:47:19.801 I/wpa_supplicant( 1218): CTRL-EVENT-STATE-CHANGE id=0 state=7
10-18 16:47:19.801 I/wpa_supplicant( 1218): CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]
10-18 16:47:19.801 V/WifiMonitor( 1168): Event [Associated with 00:1d:7e:ad:33:30]
10-18 16:47:19.801 V/WifiMonitor( 1168): Event [CTRL-EVENT-STATE-CHANGE id=0 state=7]
10-18 16:47:19.801 V/WifiMonitor( 1168): Event [CTRL-EVENT-CONNECTED - Connection to 00:1d:7e:ad:33:30 completed (reauth) [id=0 id_str=]]
10-18 16:47:19.801 V/WifiStateTracker( 1168): Changing supplicant state: ASSOCIATED ==> COMPLETED
10-18 16:47:19.801 V/WifiStateTracker( 1168): New network state is CONNECTED
10-18 16:47:19.831 D/WifiWatchdogService( 1168): (android.server.ServerThread) homer (00:1d:7e:ad:33:30) does not require the watchdog
10-18 16:47:19.891 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:47:19.981 I/ActivityManager( 1168): Process com.tni.TasKiller (pid 2229) has died.
10-18 16:47:20.531 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@304fd088 (uid=1000 pid=2152)
10-18 16:47:20.541 W/IInputConnectionWrapper( 2152): showStatusIcon on inactive InputConnection
10-18 16:47:20.571 I/ActivityManager( 1168): Displayed activity com.levelup.beautifulwidgets/.ForecastActivity: 1017 ms (total 1017 ms)
10-18 16:47:21.044 W/KeyCharacterMap( 2235): Can't open keycharmap file
10-18 16:47:21.044 W/KeyCharacterMap( 2235): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:47:21.044 W/KeyCharacterMap( 2235): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:47:21.111 W/IInputConnectionWrapper( 2235): showStatusIcon on inactive InputConnection
10-18 16:47:23.411 W/KeyCharacterMap( 2152): Can't open keycharmap file
10-18 16:47:23.411 W/KeyCharacterMap( 2152): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:47:23.411 W/KeyCharacterMap( 2152): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:47:24.101 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@304fd088 (uid=1000 pid=2152)
10-18 16:47:24.101 W/IInputConnectionWrapper( 2152): showStatusIcon on inactive InputConnection
10-18 16:47:25.101 I/ActivityManager( 1168): Starting activity: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10000000 cmp=com.handcent.nextsms/com.handcent.sms.ui.ConversationExList }
10-18 16:47:25.341 D/sss ( 1590): 1287413245343
10-18 16:47:25.381 D/WifiService( 1168): ACTION_BATTERY_CHANGED pluggedType: 0
10-18 16:47:25.661 W/IInputConnectionWrapper( 1693): showStatusIcon on inactive InputConnection
10-18 16:47:25.671 I/ActivityManager( 1168): Displayed activity com.handcent.nextsms/com.handcent.sms.ui.ConversationExList: 516 ms (total 516 ms)
10-18 16:47:26.811 I/ActivityManager( 1168): Starting activity: Intent { cmp=com.handcent.nextsms/com.handcent.sms.ui.ComposeMessageActivity }
10-18 16:47:27.181 I/ActivityManager( 1168): Displayed activity com.handcent.nextsms/com.handcent.sms.ui.ComposeMessageActivity: 368 ms (total 368 ms)
10-18 16:47:28.365 I/WindowManager( 1168): Setting rotation to 1, animFlags=1
10-18 16:47:28.365 I/WindowManager( 1168): Config changed: { scale=1.0 imsi=0/0 loc=nb_NO touch=3 keys=2/1/1 nav=1 orien=2 layout=17}
10-18 16:47:28.671 I/ActivityManager( 1168): Start proc com.tni.TasKiller for service com.tni.TasKiller/.TasKillerLauncher: pid=2244 uid=10084 gids={3003, 1015}
10-18 16:47:28.681 D/StatusBar( 1168): updateResources
10-18 16:47:28.711 D/JorteService( 1612): Thread idling wakeup
10-18 16:47:28.721 D/JorteService( 1612): Thread idling wait next
10-18 16:47:28.761 I/ActivityManager( 1168): Process com.levelup.beautifulwidgets (pid 2235) has died.
10-18 16:47:28.881 I/ActivityManager( 1168): Start proc com.levelup.beautifulwidgets for broadcast com.levelup.beautifulwidgets/.HomeWidget: pid=2250 uid=10077 gids={3003, 3002, 3001, 1015}
10-18 16:47:29.371 I/WindowManager( 1168): onOrientationChanged, rotation changed to 1
10-18 16:47:29.491 D/Beautiful Widgets( 2250): UserPresent
10-18 16:47:29.491 D/Beautiful Widgets( 2250): It has been less that 10 min since last weather refresh, do not refresh!
10-18 16:47:29.491 D/Beautiful Widgets( 2250): Screensaver mode: true
10-18 16:47:29.511 I/ActivityManager( 1168): Starting activity: Intent { act=com.levelup.beautifulwidgets.action.screensaver flg=0x10000000 cmp=com.levelup.beautifulwidgets/.ForecastActivity }
10-18 16:47:29.581 I/ActivityManager( 1168): Process com.android.settings (pid 2152) has died.
10-18 16:47:29.751 D/Beautiful Widgets( 2250): OnCreateForecast from widget
10-18 16:47:30.481 I/ActivityManager( 1168): Displayed activity com.levelup.beautifulwidgets/.ForecastActivity: 963 ms (total 963 ms)
10-18 16:47:31.291 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:47:31.791 I/ActivityManager( 1168): Process com.tni.TasKiller (pid 2244) has died.
10-18 16:47:32.031 W/IInputConnectionWrapper( 1590): showStatusIcon on inactive InputConnection
10-18 16:47:33.911 W/IInputConnectionWrapper( 2250): showStatusIcon on inactive InputConnection
10-18 16:47:37.401 I/ActivityManager( 1168): Process com.levelup.beautifulwidgets (pid 2250) has died.
10-18 16:47:43.461 I/ActivityManager( 1168): Start proc com.tni.TasKiller for service com.tni.TasKiller/.TasKillerLauncher: pid=2258 uid=10084 gids={3003, 1015}
10-18 16:47:45.951 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:47:59.771 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:48:00.031 I/ActivityManager( 1168): Start proc com.levelup.beautifulwidgets for broadcast com.levelup.beautifulwidgets/.HomeWidget14: pid=2263 uid=10077 gids={3003, 3002, 3001, 1015}
10-18 16:48:01.241 I/ActivityManager( 1168): Process com.levelup.beautifulwidgets (pid 2263) has died.
10-18 16:48:09.821 W/KeyCharacterMap( 1590): Can't open keycharmap file
10-18 16:48:09.821 W/KeyCharacterMap( 1590): Error loading keycharmap file '/system/usr/keychars/mimmi_keypad.kcm.bin'. hw.keyboards.0.devname='mimmi_keypad'
10-18 16:48:09.821 W/KeyCharacterMap( 1590): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
10-18 16:48:14.081 I/WindowManager( 1168): Config changed: { scale=1.0 imsi=0/0 loc=nb_NO touch=3 keys=2/1/2 nav=1 orien=2 layout=17}
10-18 16:48:14.221 D/StatusBar( 1168): updateResources
10-18 16:48:14.301 I/WindowManager( 1168): onOrientationChanged, rotation changed to 0
10-18 16:48:14.301 I/WindowManager( 1168): Setting rotation to 0, animFlags=0
10-18 16:48:14.301 I/WindowManager( 1168): Config changed: { scale=1.0 imsi=0/0 loc=nb_NO touch=3 keys=2/1/2 nav=1 orien=1 layout=17}
10-18 16:48:14.441 D/StatusBar( 1168): updateResources
10-18 16:48:14.461 D/JorteService( 1612): Thread idling wakeup
10-18 16:48:14.481 D/JorteService( 1612): Thread idling wait next
10-18 16:48:14.721 I/ActivityManager( 1168): Stopping service: com.tni.TasKiller/.TasKillerLauncher
10-18 16:48:15.891 W/InputManagerService( 1168): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@303f2b20 (uid=10076 pid=1590)
10-18 16:48:15.891 W/IInputConnectionWrapper( 1590): showStatusIcon on inactive InputConnection
10-18 16:48:25.082 I/ActivityManager( 1168): Starting activity: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.xtralogic.android.logcollector/.SendLogActivity }
10-18 16:48:25.431 I/ActivityManager( 1168): Start proc com.xtralogic.android.logcollector for activity com.xtralogic.android.logcollector/.SendLogActivity: pid=2270 uid=10103 gids={1007, 1015}
10-18 16:48:25.871 I/ActivityManager( 1168): Displayed activity com.xtralogic.android.logcollector/.SendLogActivity: 708 ms (total 708 ms)
10-18 16:48:26.191 I/ActivityManager( 1168): Process com.tni.TasKiller (pid 2258) has died.
10-18 16:48:26.911 I/global ( 2270): Default buffer size used in BufferedReader constructor. It would be better to be explicit if an 8k-char buffer is required.
Hope this helps :-)
christian_a_torres
Forgot to add that i appreciate that you take the time to see if these issues can be dealt with. If issue 1 and 3 as per first post get fixed I reckon many Xperia Mini pro users would be happy :D
christian_a_torres
Wondering if there are any updates on this issue? Cheers :ugeek:
no, had other thing to do with more priority
don't worry it's still in the todo list ;)
christian_a_torres
Issue 1 has been solved with me replacing the file /system/usr/keychars/mimmi_keypad.kcm.bin with the one from a Norwegian Xperia Mini Pro. This file is the one that maps the keys of the hard keyboard and is the file used by third party text input applications :D
Issue 2 is basically a non issue since, as previously mentioned, Smart Keyboard has a sort of different icon over the flashing cursor when using this blue function key. So its possible to distinguish where you are in the function realm. :D
Issue 3 is the one to fix. If this is possible Smart Keyboard would be the only 3rd party text input method to have this working for the Xperia Mini Pro's out there ;) Maybe it helps that in the file /system/usr/keyboard-config/layouts/qwerty-no-dk.xml (and all other layout files in that directory) Sym/áü button is id'ed as:
<key id="216"
meta="META_SYM"/>
Thanks for your continued help in this matter, hopefully it wont be to long before this can be fixed :D
christian_a_torres
Just wondering if there is any progress on the matter :)
Son Goku ssj4
Hi. I've got a new xperia x10 mini pro phone for a month now and I've got the -same- problem.
Is there any progress? That would be awasome.
The Sym button just keeps doing the same thing as blue-square bottom-left.
I've got your Smart Keyboard Pro 3.16.0.
Physical Keyboard - disabled
Sorry, no news on this one at the moment.
