Hello!
Would it be possible to create an Unicode input? That new keyboard layout would only need the numerals 1-0 and the letters A-F. If you then enter a unicode value, Smart Keyboard would automatically change it to the character.
For example: Type 01DA and get ǚ.
Would also be nice if it not only supports the BMP, but also the other Planes (16 Bit).
I think this would be nice to be able to type some special characters, not found on any keyboard.
