Suggest something in Korean keyboard
iddasi22
Hi, I'm using your keyboard app.
I have a suggestion.
If I changed the layout from English to Korean (or short vowel) with Caps Lock being enabled, the state of Korean layout is still capitalized.
But I wish the Caps Lock was disabled automatically in that situation.
Because, the Caps Lock is used less frequently in Korean.
thank you.
You're right that's a problem. Fixed in the next version
