3.8.0/3.8.1 suggestions always on
dbharris
In 3.8.0/3.8.1, word suggestions seem to be unconditionally enabled. I've tried toggling it a few times (and even enabling it just in case the meaning had been inverted by accident), but no luck.
UPDATE: Sorry, looks like it's only in some widgets. For example, the Market search input box widget. But I'm sure I've seen it elsewhere. Thanks again.
Thanks,
Dave
Can you detail exactly your configuration? What is this "market search" widget? (is it "google search" widget for apps?) Do you have other examples?
dbharris
Not "widget" as in home screen widget. "Widget" as in user interface widget.
It looks like predictions are shown for any search box. In the Market app (which I described before), the global Quick Search Box, inside FBreader, and probably others as well.
Thanks,
Dave
I cannot reproduce your problem with "show suggestions" off
Can you backup your settings to the SD card and send your file /sdcard/smartkeyboardpro/backup.zip to smartkeyboardpro at gmail.com ?
dbharris
Sorry, I hate it when people do this to me too, but I re-installed Smart Keyboard Pro for an unrelated reason and the problem disappeared.
