Scroll jump
frxxman
Hi Smart keyboard
I have a strange problem.
When I activate Smart Keyboard scroll in all aplication is affected in a bad way.
It jumps a couple of "lines" aroud where I started the scroll wit my finger.
I think it is strange because I suppose that your application only is active when one taps in a text field.
But I can easily recreate problem by ectivating and deactivating your app.
I have to admit that this is a problem that will stop me from using your app.
Can you fix it? I haven't found a post talking of this problem.
Regards Martin Freeman
there is no logical explanation to this problem, so have you tried to restart your phone after activating the keyboard? (which is the solution to most illogical problems ;) ) ?
frxxman
Hi cyril.
I didn't want to live with the error.
So I downloaded slide-it instead. But when I chose slide-it as input mode it also happened with that app. Am I the only one experiencing this? Do you know any one with a Legend that could replicate the error.
Off cause I uninstalled slide-it and got a refund. I want to use smart keyboard when problem disappears.
Please help someone.
Regards Martin
