Downloading with tapatalk
tryll1980
Is it possible to download skins with tapatalk? The download guide talks about using zip files, but I only find png's
Sent from my Legend using Tapatalk
Indeed it doesn't seem to work :( I will update the user's guide and contact them about this problem
tryll1980
I've found out how to download via tapatalk. Each post with a skin in it had 2 icons in it. One showing the skin, and the other showing just in all white. Click the white one, but you won't see a picture. Don't worry about that. Click in it just as you would save a picture. The option to save still pops up. Click it to save. Now use a file browser and find the tapatalk download folder. In there you'll find a jpg image, but it's not a image. It really is the zip file. Rename the «image» name to whatever.zip and move the file to a folder on the root of your sd card named «skins». The next time you're choosing a skin it'll show up in the list. Yay!!
