Arrow and del button are blank on My Touch 4G
andriykachala28
The Up arrow key and del key are blank (there is no sign o them), if I try to use GlossBlack, 3D Key, Brass, Droid or galaxy skin.
With other skins everything is fine.
Will appreciate any help.
Thank you,
Andriy
Do you mean you have no problem with other skins posted on the forum (if yes, which ones?), or only with the builtin skins?
Can you show your phone logs (with "Log Collector" or adb logcat) at the time you load the skin (when you change it in the settings)?
