I am wondering if there is a way to configure this so you press and hold shift for caps like a normal keyboard and then release to return to lower case. When I try this now, it works for caps but release doesn't return to lowercase. A cool feature here might be an option to ignore words in all caps since they are likely to be acronyms or abbreviations.
Also, can autocomplete and correction include things like "can't" if it is typed like "canct"? Note that C is under the '.
