keyboard gets VERY slow when entering text in browser :(
hi all,
generally liking SK - works well in all other areas but get so slow when entering text in internet browser when writing a post
Literally takes a second for it to register a letter :(
If it is slow only in the browser, it's much likely that the browser can cause the problem... (the behavior of the keyboard is not supposed to depend on the app in which it is used)
Can you get "Log Collector" and show your phone logs at the time you type in the browser and see this problem?
hi again
yes could be browser. I'm using dolphin hd.
will try and get logs.
btw. just typed 'yed' instead of yes and it wasn't
corrected
hi all
have just tested slow issue with standard browser and the problem is there too
so have to assume it is SK. sorry
although is running nice and quick on here at mo :-D
I mean, does it happen in something else than a browser?
hi. sorry. don't think so. just seems to be internet use based issue so far
