help! cant re-enable SKP ?! :/
hi Cyril,
i disabled SKP for testing and now cant re-enable it! ive even uninstalled and re-installed it
The usual way... check the keyboard in language & keyboard settings, then long press in any input text box and select "Input Method" in the popup menu
Ah right. Thanks. Forgot about the 2nd part
Cheers
Dan
