Weird issue with Dolphon Browser
Fat Fingers
When I am trying to enter a URL with the Dolphin Browser, I am having a problem. Let's say i am trying to enter http://www.cnn.com
I am fine through http://www.cnn but then when I type the next ".", it wipes out the cnn and I end up with http://www..
This does not happen with Stock Keyboard.
IF I turn off Quick fixes, the problem goes away.
I have Autocomplete turned off but Quickfixeds and Show Suggestions turned on. I wanted to try turning off Quick fixes, but leave Show Suggestions on, but I was not able to do so. I reported this issue on another thread.
Someone else told me that, I must have a look at it...
Fat Fingers
Same problem w/ Stock Browser, not just Dolphin.
Surprised more have not reported this issue. Basically have to switch to stock keyboard if browsing.
Fat Fingers
Seems like maybe the stock browser turns off the quick fixes/suggestions when using a browser. The area where suggestions appear is there, but no suggestions appear leading me to believe it is not really on when using the browser.
Well... that's indeed due to the "Always suggest" feature I've been asked to add, which enables suggestions even when Android tells the keyboard not to do so.
But I cannot reproduce your problem (at least with the stock browser); if I type http://www.cnn, "cnn" appears in the suggestion bar, but "cannon" is highlighted, so this word is chosen if you press ".".
I'm not saying this is a good behaviour, but it's not exactly what you describe.
If you don't want this, just disable "Always suggest" (maybe I should turn it off by default, I don't know...)
I found a better solution. I will disable auto-correction in URL mode, so this problem won't happen any more, even with "always suggest" on
Fat Fingers
This issue has recurred (sort of). When sending an e-mail, if I try typing john.doe@yahoo.com in the "to address", the same problem occurs when I type the "." between John and Doe. The only way arround it is to turn autosuggest off when typing the address. Can you disable autoduggest when entering e-mail adresses as well?
Yes I'll do it in the next version
Fat Fingers
This problem, got fixed a couple releases ago, but has returned. I assume it returned with the introduction of the latest release.
Strange, as auto-correction is still disabled in e-mail fields...
Fat Fingers
A clue.....
The issue only occurs when forwarding an e-mail, not when creating a new one.
Fat Fingers
Was at a conference this week and this keyboard came up in discussion. This problem was one of the complaints I heard. Hope it can get fixed soon
Ok I will look at this again...
So you can describe *exactly* what is the problem and how to reproduce it? (please give all the needed details: predictions options used, which web site, etc)
Fat Fingers
Issue is when trying to forward an email using touchdown email client. Turning quick fixes off solves the problem.
Suppose i want to forward email to John.doe@MSN.com. if I have a contact named john as well, as soon as I type "john. " The 'john' gets wiped out and all I have left is the ".".
