AndroidBlue and GingerbreadBlue for Extremely Blue CM6 theme
hotaru
i've been using cm 6 with jeagoss's extremely blue theme for a while, and while there are several skins for SKP that look ok on it, the colors are almost always a little "off"... so i decided to make some skins that fit in better with this particular theme.
first, AndroidBlue. pretty much all i did for this was grab the images for the android keyboard from https://github.com/jeagoss/jeagoss_extblue.
External image (img51.imageshack.us)
AndroidBlue.zip 28.3 KB · downloaded 3,705 times
second, GingerbreadBlue. this is basically the result of taking the GingerbreadBold skin i made and messing with the "Levels" adjustment in paint.net until the colors looked about right.
External image (img580.imageshack.us)
GingerbreadBlue.zip 27.1 KB · downloaded 4,697 times
oshi-k
I like GingerbreadBlue very much.
Maybe a GingerbreadPink??? :-)))
Thank you!
tryll1980
Download links don't work....
Sent from my Legend using Tapatalk
hotaru
tryll1980 wrote:Download links don't work....
what links? the ones generated by the the forum to the attachments?
they work fine for me, and if they didn't, it's not like i could fix the forum software or anything...
Try outside Tapatalk, it doesn't behave well with .zip links
BigBootyJay26
I would love to see more colors and designs from these keyboards. thanx!
slinky317
I love the Gingerbread Blue skin! Can we make one with the thinner letters instead of the bolded ones?
(Posted from my HTC Droid Incredible)
dopejayoh
I know this thread is quite old but I really like the AndroidBlue skin. One thing I would like changed, however, is the color of the suggestion bar. Any chance someone can make the suggestion bar black instead of white? Thank you.
