Android 2.3 Gingerbread and SKP
onthecouch
Cyril, will SKP work with the new Nexus S, or the better question, will it work with Android 2.3 Gingerbread? Will my saved settings be able to be loaded on 2.3?
Yes, Smart Keyboard works on Android 2.3. You can restore your settings if you stored them on your SD card
