Restart & T9
kan
Hi!
Please, help me to solve the following two problems.
1. After any restart Smart keyboard Pro always disabled. I must go to the settings menu and enable it again and again.
2. How to disable T9? There is no such option.
Thank you in advance.
1) if you have this problem it must be a bug on your version of Android and I'm not sure I can help much on this...
2) T9 is off by default, so if you are in T9 mode, it's probably because you changed some settings. Check "portrait mode" option to turn T9 off
kan
Thank you for reply.
1) I'll search an additional info.
2) I mean "suggestion" in portrait mode. How to switch off suggestion?
kan wrote:2) I mean "suggestion" in portrait mode. How to switch off suggestion?
"Show suggestions" option ;) But it will be for both portrait and landscape...
kan
I found the first problem decision. It's happen because smart keyboard was placed on to the SD card. I move it back to phone and now it is working all right.
Abron
I have the same problem :-( How can I place "Smart Keyboard" back to the phone?
