...isn't working. Vibrate still works. Media volume and ringer volume are turned up to max, but still doesn't work
sound in keypress
I don't understand, it works for me... By the way the phone volume is not used by the keyboard, you have to set it in Smart Keyboard settings. Is everything set correctly there ?
I am having a similar problem where the Android sound style works, but not the iPhone sound style. Using Nexus One with stock firmware.
The keyboard uses a different method to play the iPhone sound, as it is not a builtin effect. However I never had problems with my HTC Hero, so I will wait for the Nexus One to test...
same problem here with nexus one.
I changed something in 2.0.0, hopefully it will work better
2.0.0 works. Thanks!
Same problem on my LG GT540 android 2.1
For some reason sound does`t workin(
After reinstall has not effect it
any ideas?)
any ideas?)
Keyboard sounds are system (not media or ringer) sounds, so maybe the volume of system sounds is somehow set to zero.
I am check this)
The default keyboard sounds works well.
But the Smart Keyboard not.
