Is there any way I can skin the prediction box to match my themes? Thanks.
Skin the prediction box
Not at the moment, this could be an added feature if/when I have time to do it
What if i edited the apk myself?
You're not supposed to
But of course you will be able to change the suggestion background if you do that
cyril wrote:You're not supposed toWell it'll only be for meBut of course you will be able to change the suggestion background if you do that
