User dictionary blacklist
daf
It would be great if I could add a list of words that will never appear in the suggestions.
Use case:
Imagine someone using you phone to visit youtube and getting a suggestion to some other site you visit frequelntly.
reverie
Sounds great. There are some words that are part of the dictionary but I will never use it. And it keeps popping out in the suggestions when I try to enter something else.
A workaround (which doesn't cover all the use cases) is to define a custom autotext to replace these words by what you expect
