Hi.
I love Smart Keyboard, it's much better than the one preinstalled on my Galaxy S. But there is a couple of improvements to be made when it comes to writing in T9 mode.
The letter "i" and "å" is very common in the norwegian language. It seems like Smart Keyboard is not learning the frequency of single letters. When pressing the key for the letter "i" it's always "g" that comes first. I have to choose "i" in the suggestion bar every time. Phones with standard T9 have the ability to learn the frequency of single letters as well as words. Then the letters we use the most will appear first in the suggestion bar.
When it comes to the letter "å" it's the same thing. But in addition you have to add this letter to the abc key. But not in the sense that it is visible on the key it self, but when I hit the abc key the letter "å" should appear like the other letters do. The only way to get the letter "å" now is to longpress the abc key.
Please please fix this. There are many of us using the T9 in portrait mode. Smart Keyboard will be perfect if this is fixed.
EDIT: There is already a thread about the subject here Learn the use of letters as well!
AutoText takes care of the problem for now thanks to chtamina
Mr Mozz
Mr Mozz
