Smart Keyboard Pro can't understand when I'm using the apostrophe to "split" the article from the word.
Example: "la anima" get "l'anima" (it means "the soul" in italian) with SKP I have two options:
- adding the word "l'anima" to the dictionary.
this means that for each different word I have to add the same word with the article+apostrophe in the dictionary. like "anima" "l'anima" "dell'anima" "sull'anima"
- using " l' " then SPACE then writing the word "anima" so I get "l' anima" (I HAVE to add that annoying space because otherwise SKP thinks that "l'anima" it's a new word.
so when I write I get a lot of "l' anima" "dell' anima" "sull' anima" while I should write "l'anima" "dell'anima" "sull'anima".
now my proposal is: teaching SKP that the word after the apostrophe should be considered as a new word, even if there's no space that separate the word from the article.
Swype does it so I don't think it's hard to implement.
Thanks and please let me know what you think about it
nicola
nicola
