I just got an idea for a future feature.
On Android, if you want to select text/copy/past etc, you have to hold down the text box and select what you want. Which can be a bit lengthy to do your task.
As you had allowed us to remove the comma key to make the spacebar bigger, perhaps you can add an option to replace the comma with a key that when pressed, a little menu will pop up consisting of:
Select Text
Select All
Cut
Copy
Paste
I haven't seen this feature implemented in any other keyboard.
OR, use gestures to activate the menu?
I'm sure this will be very useful to a lot of people including me!
Did a quick mockup
you press the menu button to open the menu. press the button again to close.
the menu covers the keyboard so it doesn.t cover the text box on the main screen like the default android menu does.
I really hope this gets implemented soon!
Select Text
Select All
Cut
Copy
Paste
Did a quick mockup
