Unable to install
chiacchio
I had bought the app, but eventually I asked for refund because, though I enable it in settings, it didn't work (I had always the old keyboard)... I'm still willing to buy it, but it should work first, don't you think? :)
I have mytouch 3g with android 1.6
tnx
There are general issues with android market since yesterday, there is nothing I can do to help at the moment...
chiacchio
Ok, can you please let me know when these issues are solved? Thank you!
I don't know, I don't work for Google ;) I just also noticed myself issues to purchase (other) apps yesterday, as everybody else.
BUT I read your post too fast... you said you managed to download it actually ? Then it has nothing to do with the problem I talked about ...
Did you read the FAQ first, to change the keyboard ?
How do I enable the keyboard? Go to "Language and keyboard" settings, and check the "Smart Keyboard" (or "Smart Keyboard Pro") box. Then chose "Smart Keyboard (Pro)" in the "Input method" dialog, which appears after a long press in any text input box.
chiacchio
You'right! I missed the last step. However I had taken a look to the FAQ, but there where too many questions, mostly concerning the use of the website, that I was not interested in... I think you could focus on specific questions about your great product!
Bye,
Chiacchio
