I have the Droid 2 Global, Android Version 2.2. The default keyboard for this phone as an ALT lock option which keeps the ALT on so I can enter multiple numbers or symbols without having to press the ALT key a bunch of times or using the touch screen keyboard. This option was disabled when I installed the Smart keyboard, but works fine when I stop the Smart Keyboard. Is there anyway to turn this option back on while I'm using the Smart keyboard? I've tried chaning around a bunch of settings but can't seem to find it.
Thank you,
Chrissy
Thank you,
Chrissy
