Is there a way to make a suggestion the primary suggestion? For example you misspelled this and you typed thus. They primary suggestion is thus but I want it to be this so I can keep typeing instead of having to manually press this. Possible?
suggestions
Yes, that's one possible usage of the "custom autotext" feature. Just define an autotext thus -> this
shouldn't suggestions be prioritized from use?
example: each time i write "più" i get "Shu" as the second suggestion and "sito" as the third suggestion. now i NEVER selected "shu" because it's not an actual word but i tapped on "sito" like a million times. i think i should get "sito" as the second suggestion and "shu" as the third one.
what do you think about it?
