Dictionary not Learning New Words
levimsmith
I have the smart dictionary enabled and I installed the English dictionary, but the dictionary still won't learn anything. I am using the T9 keyboard and if I press the 4 key and space so as to start a sentence with "I" it puts a "G" in its place despite adding "I" to the dictionary. The same thing happens with simple words like "haha". I can add a word to the dictionary and immediately return to the text to type the word again and it does no good. Any suggestions?
hi,
i think this is a similar issue to what i get using compact keyboard - i have 'learn new words' turn on, but when typing new word, it isnt offered in the suggestions bar, so there is no way to add it - only way to get around this is to go to the custom word option in settings and map the word it gives you to the new word you want
SaKeygo
I didn't notice this problem at first. It only seems to be affected when typing in a search field (google or the search on this forum). When typing an E-mail or using a notepad app the I appears to function normally.
If it's happening in a notepad app, it may be the notepad app that's doing it. Some of them will override SKP (and some other keyboards), though not often.
levimsmith
It happens no matter what application I am in. Its most irritating in the text message setting when using the T9 keyborad. It's disappointing to pay for a program that doesn't function as it is advertised.
hi
sorry to hear that. I agree there are some inconsistencies between the
keyboard styles. I think the dev really needs to sort out a more direct way
of logging faults like other apps. ie direct email from the market place.
think it might help speed up support process. Cyril ?
SaKeygo
I turned off t9 and added haha manually without any problems. I think you have to do it that way if you want to add a new word to the dictionary.
As far as I becoming g, you could try using the autotext to do something like:
The following word: g
Will be replaced by: I
To force g to become I
(Unless that's what you meant when you said "added I to the dictionary")
yes I think you are correct with that.
I use compact mode and that doesn't always work
with learned or custom words. but landscape QWERTY does.
odd
dab
chtamina
which version are you using?
hi
I'm not sure of the version no but it is the latest
one in the market with uk dictionary
Dan
chtamina
I'm not experiencing any problems at learning new words with that version
