Long key press behavior
notuo
Hi all. This happens in QWERTY layout.
I noticed when you long key press the menu for all options appear as expected but the default option is the number. (anyone else?)
My concern is depending on the type of use of the keyboard (text or numbers) the default option should be TEXT based in the language you choose and of course not the number.
Example: I am typing in Spanish the word: "camión" when I arrive to the o I long keypress the o and I got 3 options, °, ó and 9 and 9 is the default. Meaning if I stop pressing the o a number 9 is typed.
I think the correct behavior should (the default option) be based in:
Language you are using.
The most used of the options not the numbers.
Any thoughts?
Regards
