If you could change the color of the Prediction box, that would be pretty cool.
Prediction Box Color
The prediction box background is an image, not a color, so it cannot be changed easily, unless it's part of the skin itself (a modification is required in the skin engine)
i believe that the color is just fine, I think that the size should be increased.
I guess it's a lot more difficult than changing the color of the words in the prediction box, then. Couldn't there be a few "images" to choose from that are just solid colors? Just stabbing in the dark, as I have no idea.
I'd like to see this feature too, but it's only for aesthetics and isn't that important.
cyril wrote:The prediction box background is an image, not a color, so it cannot be changed easily, unless it's part of the skin itself (a modification is required in the skin engine)
I was hoping to change it black. Mainly because the white/light gray doesn't go well with my overall theme.
I'd also like to change mine to black... the devs should make an image over lay so we can change the color as we please... like the word candidate color.. just sayin.. but for the most part... a black background would suit me best. The only problem i've ever had with this keyboard is that prediction box color.. everything else has been flawless for me. this keyboard easily has the nicest skins available. (used better keyboard for about 4 days, i liked the black prediction box, but they keyboards calibration or something was off. and all the keyboards have something wrong with them appearance wise. (most of them are just ugly).) Now i'm back to smart keyboard hoping i can find a way to change this
platinumrims wrote:I'd also like to change mine to black... the devs should make an image over lay so we can change the color as we please... like the word candidate color.. just sayin.. but for the most part... a black background would suit me best. The only problem i've ever had with this keyboard is that prediction box color.. everything else has been flawless for me. this keyboard easily has the nicest skins available. (used better keyboard for about 4 days, i liked the black prediction box, but they keyboards calibration or something was off. and all the keyboards have something wrong with them appearance wise. (most of them are just ugly).) Now i'm back to smart keyboard hoping i can find a way to change this
I agree. I am using a modified gingerbread keyboard. I love Smart Keyboard, but I need to change the prediction box image...
Yes it could easily be added in the skin XML, but there are some technical issues raised by skinning the prediction bar. I would have to rewrite a lot of code to make this work, but nothing impossible.
Sounds more effort than it's worth. I might suggest though: if you ever do do a substantial amount of code re-working to allow skins more control, perhaps skins could be allowed to specify custom keylout(s)? I hope you understand what I mean, a skin could come with a database/xml/whatever defined along the lines of "button id (1) ; begins (0,0) ; ends (10,25) ; action (q)" etc.
I realise that's a massive massive code meltdown, but just throwing it out there
