y in Spanish
dani.nedan
Hi there...
i use smart keyboard pro and have it configured in compact-mode with spanish language.
As you probably know, "y" in Spanish means "and" so its a word often used. My problem is by pressing the "ty" key the first letter that appears is the "t" and not the "y". I cannot add the letter "y" as a new word to give it priority over t because apparently it is to short to be added as a word.
How can I add "y" as a new word?
this is explained in the user's guide, you can do it by using the custom autotext feature:
- redefine the default letter when using the T9 layout. For instance you can define an autotext to replace "t" by "u," so that "u" becomes the default choice when you press the "tuv" key in T9
dani.nedan
Thank you very much! Solves my problem perfectly ... and sorry for not reading the user guide ..;-)
