Hi, I just bought app.... I followd youtube and direction. However, I cannot get this app to work!! After going to Lnagage & Keyboard, There is no androig key board setting or international language setting....
Could someone help me to start this app to work please??
so, what do you see when you go in "Language & keyboard settings" ? You should see a list of keyboards in "Keyboard Settings" submenu. If you don't see Smart Keyboard Pro it means it was not installed; have you checked in the market it is marked as "installed"?
Oh Sorry...Yes I see select language, Smart Keyboard Pro, Smart Keyboard Pro with check mark, and TOuch Input. I was referring to Youtube demonstration...
I pressed Smart Keyboard Pro with check mark until Attention boxk poped up. I pressed ok. I would like to be able to use Japanese language....how do I set my phone to be able to do this....??
Make sure you changed the current input method as in the youtube video (long press in a text box until a popup menu appears, and select "Input Method", then "Smart Keyboard Pro"). You also need to install "Japanese for Smart Keyboard" app, and change the language in the keyboard settings.
