Norwegian T9 problem
octane
When in T9 mode, the letter "Å" is supposed to be located at the number 2 digit together with A B C, but its not there.
Also, the letter "Å" is a single standalone word.
Hope you can fix this is the next update, other than that its a great app! Thanks :)
actually it's available with a long press, but it can be included in multitap if needed. Is this needed for other letters?
Meanwhile a workaround is to define a custom autotext to replace "a" by "å"
lkindem
same here...and autotext IS NOT a good solution. I switch between ENG and NOR all the time...hence making å default for a covering all languages is not good enough. Pls, this can not be a big thing to fix! This is the reason why I'm not using Smart Keyboard as default...as the letter å is used A LOT in Norwegian...
So pls fix this! Thank you!
/lars
