Individual Row Key Height Adjustment
Any chance we could get individual row key height adjustment? At the very least for the bottom row, I commonly hit the "c" and "b" keys when meaning to press the space bar (or make a feature that recognizes two words together joined by a "c" or "b" and auto deletes the extra letter and places a space. It would also be helpful on the top row, I also commonly hit the "e" or "r" key when reaching for the question mark or comma, respectively. Thanks for the opportunity to voice my opinion.
I think you should have fewer issues with the space bar if you use the new option "bottom padding", don't you?
Thanks for the suggestion, but no. Even with padding it just moves my entire typing position up, leaving me with the same issue. That's fine though, apparently I'm the only tard with the problem anyway. Thanks for the Rad keyboard Cyril.
London
I would really like this feature too.
I'm using SKP, typically T9 in vertical, on a small SE X10 mini, and screen space is valuable. I would very much like if I could adjust the height of the lowest line, making it smaller. I can easily tap all keys on this line putting my finger more than half off the screen, and such a feature would give me more free screen for reading what I'm writing and previous messages.
Being able to adjust column width (individually) would be great, too, as typing half off-screen would be no problem for the left/right columns, but could allow bigger buttons for typing in the middle.
