auto suggest sometimes doesn't work
olivierm
When typing the suggestion engine sometimes loses it, even on words that it knows. Was typing "circonstance" in french and the suggestions stopped at when I reached "circonsta".
In some occasions, when typing a word that draws a blank in the suggestion engine, the right suggestion appears after erasing and retyping the word, even with the same typo if there was one.
Works fine though but these mishaps make me slow down a lot. Anyone with the same problem ?
imekul
I have noticed that, as well. I haven't yet figured out any sort of pattern to it.
Found a bug causing this symptom. It's hopefully fixed in 1.22.2 ! The pattern was: start pressing on a key, move your finger and release the finger on another key; it was messing up the prediction algorithm
mttmllns
Glad to see you found and fixed the bug. I've noticed an improvement.
