AndroidUser wrote:As you can see the first screenhot is from my review of Smart Keyboard on Market. So the answer to your question is that it's indeed an Android keyboard.
Brgds...
After checking around I am guessing that screenshot is the default keyboard on the HTC EVO, rather than a third party keyboard. The only similar third party Android keyboard I've seen with arrow keys like those ones is Ultra Keyboard, which implements them pretty much identically to the screenshot shown. On my Dell Streak however, Ultra runs too slowly to allow fast typing, whereas Smart Keyboard Pro runs lightning fast and never misses keystrokes no matter how quickly I type. So adding the arrow keys to SKP would be the ideal solution in my opinion. They are just so completely essential for smooth and fluid text editing/correction.
Currently to correct a typo you must do:
Two taps of 123 button or swipe gesture, to switch to arrow keypad Move cursor to desired position using arrow keys, and backspace over typo
Tap ABC button or swipe gesture, to switch back to regular qwerty keyboard Type correct letter to fix typo
Two taps of 123 button or swipe gesture, to switch to arrow keypad Move cursor back to original position
Tap ABC button or swipe gesture, to switch back to regular qwerty keyboard Continue typing where you left off...
That is four different times you must switch layouts, in order to correct a typo. With arrow keys on the main layout it would just be:
I know there is already consensus in this thread regarding this.. I am just really hoping the developer realizes the importance of implementing this feature.
