I don't know if it is just my phone but recently a lot of my words are doubling the first letter llike tthis. really weird. samsung vibrant on froyo.
ttyping llike tthis recently?
Yup, this is a problem with Smart Keyboard Pro. Using a DroidX and i switched 'Input Method' from Smart Keyboard Pro to the default keyboard and it hasn't done it since.
Same is happening to me. DX
Looks like a problem specific to some phones (never saw this on HTC phones). Does "recently" mean "since version 4"?
It only started happening to me after the most recent update.
Yeah I think it was a recent update and then I started seeing it. Maybe 3-4 months ago.
as of recent update for me too- it doesn't do it to every word, just randomly but it does it a lot. recently being i guess for about a week for me
hurleygurlie2388 wrote:as of recent update for me too- it doesn't do it to every word, just randomly but it does it a lot. recently being i guess for about a week for meAnd what if you disable "touch to correct" feature? That's the only big change in the last updates.
Also, can you try the latest beta? I did some agressive code optimizations which should result in a 30% performance increase. Hopefully this could fix this problem...
so i disabled the touch to correct and typed the quick brown fox jumps over the lazy dog like a hundred times and didn't see anything and then i turned it back on and still couldn't get it to do it. i also can't tell you if it happens on landscape or not but i use landscape a lot... i also went through old messages and typed words it did it to over and over and couldn't get it to mess up... so i'm just gonna dl the beta because last time i had a problem beta helped 100% if there is an update in the market should i update or keep beta? thanks for everything cyril
As usual, the next version on the market will be based on the latest beta.
Downloadad the beta and am testing. So far so good (typing on beta)
will report feedback later, thanks
The place i notice it most is on facebook whether on the mobile version through the default browser or on dolphin hd mini for my droid x.
Seems to be working a little bit better with the beta. In the market it says there is an update for smart keyboard pro. Should i update to it or just keep using the beta?
okay so i started beta and i went to type "round" and it came out rouround!! i have since done a factory reset on my phone and the newest available on the market does the same thing but not as frequent as the original ttyping llike tthis.
This problem may be related to that one
I found another bug causing repeated letters, which is also present in Gingerbread keyboard and all its clones. It happens when you type quickly a word just after a number (quite easy to reproduce once you know when it's supposed to happen!)
This is fixed in the latest 4.2.3 beta.
