skins make
yakie996
would somone when he makes a skin make there an video that i can see how it works?? :D
it would take too much time to the one who will make the video, and it wouldn't be helpful for you since everyone uses some tools they personally master. Ones would use the GIMP with google draw9patch, others would use only photoshop, other others would use Paint.NET, etc... in addition, we all forget a single detail while making a skin, and it's hard to understand when the maker switch from XML editor to picture editor again and again and again... each time to do a little little change!
all you need is a bit knowledge in picture edition, and a guide to follow...read the post from cyril, it contains every single information you may need, and even a sample to work on. You can give a look at my pdf guide too : http://lepetitpingouin.fr/smartkeyboard/tuto.php
yakie996
meyergre wrote:it would take too much time to the one who will make the video, and it wouldn't be helpful for you since everyone uses some tools they personally master. Ones would use the GIMP with google draw9patch, others would use only photoshop, other others would use Paint.NET, etc... in addition, we all forget a single detail while making a skin, and it's hard to understand when the maker switch from XML editor to picture editor again and again and again... each time to do a little little change!
i will do it whit http://lepetitpingouin.fr/smartkeyboard/tuto.php but when i will open draw9patch it won't open.. help..
ensure you downloaded the last version of the SDK, you have the latest Java version and you correctly extracted the whole android SDK, then it should open
yakie996
meyergre wrote:ensure you downloaded the last version of the SDK, you have the latest Java version and you correctly extracted the whole android SDK, then it should open
don't work...
any error message ?
EDIT :you can try the setup file instead of the zip one from google, maybe it could help..
yakie996
meyergre wrote:any error message ?
what do you men and no no error only for less than a second u black window .... and than notting..
That's CRAZY... well you can make a skin without this tool, just have a look at the google's documentation on 9 patch, and then apply the rules directly one your picture editor ;)
Basically, you just have to add a 1 pixel transparent line all around your picture, and paint in black the areas which should expand. Look at any .9.png file one the themes around here, you should understand quickly ;)
Sent from my Adam using Tapatalk
yakie996
tanx for the quickly sevice xp but i give it up.. i let this work over on proffesionals :D
