Can we have Adjustable Key Height?
bsloanindy
Smart Keyboard Pro is really awesome--thank you for your hard work on it.
There's another keyboard out there (doesn't work nearly as well), but a nice feature it has is adjustable key height so you can make the keys almost square (or taller if you wanted I guess). This helps make the keyboard screen footprint smaller, and makes the distance your fingers have to traverse between keys shorter, too.
I suppose this could also be done through a skin? But a quick "settings" option would be great.
Keep up the excellent work! Such a great product!
>bsloan
yes it's in the TODO list, I will do it some day
At last there is a new option "key height" in the latest beta!
boowalley
Luving the adjustable height on the keyboard. Its hard to make a mistake using the bigger keys. Thanks again for another excellent update.
Zarch
Is it possible to have a "return to defaults" button added?
Once i've played with the setting, it would be good to go back to stock settings.
Also, it might be useful to show a warning that you will need to re-calibrate after changing the keyboard size?
Zarch
zen wrote:
Zarch wrote:Is it possible to have a "return to defaults" button added?
Tapping the corresponding G1 icon (to the left) would return it to default. http://www.dexilog.com/smartkeyboard/fo ... t=30#p3273
Cool, thanks.
Not obvious at all from the calibration screen though..... maybe a note needs adding?
