Speech to text - Czech
The_ERROR
I red about problems with this tool and I have same problem - on english keyboard it works fine but on czech doesn't work at all - "Server error". Although czech language is not supported (google say), with original android keyboard it works great but with smart keyboard not.
//Edit: I found thread with link to new version, but it not works.
Indeed the reason is simple: I used "CZ" instead of "CS" for the language code (it's a mistake) so Google server doesn't recognize it...
Working on a fix
The_ERROR
Yes, becouse we are using CZECH language it must be clear, that short name for our language must be CS!! :D
Anyway, this beta works great, so thanks for help!! Your keyboard is realy smart! ;) Keep going!!
lukewesley
This problem may be due to change of language.You can try to test beta with english.Hope so your speech to text will be solved.
The_ERROR
Quite old responce, check the date ;) It is working fine for while...
