Hey Cyril,
So people (myself included) are always asking about ways to improve lag, sending you logs, and just finding out that it's not SKP that's lagging our typing, it's our own phones doing it. I know this because I get the exact same lag with all the other keyboard I use (except Swype, but that's not the same breed here).
In the logs, you can see that delay that occurs and is perceived as lag. Do you know what in particular is causing the lag? Is it an abundance of apps, or too many things running in the background (under the "running services" menu in the applications settings)? Or is it running a home replacement such as Launcher Pro or ADW Launcher adding to the lag?
Any tips you know of would be great. I have quite a bit of stuff on my Incredible, and I could live without a lot of it if it meant reducing my lag significantly.
E
E
