Hello, I am an italian user, I've been using SKP for a couple of months now and i came here to provide some feedback to improve SKP behaviour with the italian language.
Stated that i use 99% of times the T9 layout, here are my suggestions:
1- First of all, i totally agree with the necessity to fix the apostrophe issue. As stated before, the perfect behaviour of SKP should be, whenever a ' is typed, to consider the following typing as a separate word to be searched on the dict. In that way SK would not look in the dictionary for "l'word" wich 99% of the times is not there, but just for the "l'word" wich will hopefully be there! This would be a huge improvement as italian language makes a huge use of "elision" with many different words like articles, prepositions, etc.
2a- Single tapping behaviour: italian language makes a very large use of these single vowels: e, i, o. I believe that typing experience would be much more comfortable if tapping "6" would give me "o" as a first choice instead of "m" (wich is never used as a single letter in italian). Same exact thing for "4" giving me "i" instead of "g" and 3 giving me "e" instead of "d".
"E" is the italian conjunction (like english "and"); "i" is an article, (like english "the") and "o" stands for "or". This quick explanation just to let you imagine how many times italians use these single letters, and how much better it would be to have these vowels instead of the consonants when tapping the relative keys.
2b- Another thing I would like to suggest on the single tap of the numeric pad is to give a wider variety of predictions. I'll go straight to the point:
Tapping "2" should give me these predictions: a, b, c, à, 2
Tapping "3" should give me: e, d, f, è, é, 3
Tapping "4" should give me: i, g, h, ì, 4
Tapping "5" should give me: l, j, k, 5
Tapping "6" should give me: o, m, n, ò, 6
Tapping "7" should give me: p, q, r, s, 7
Tapping "8" should give me: t, u, v, ù, 8
Tapping "9" should give me: w, x, y, z, 9
That way it would be more comfortable to insert numbers and accented vowels, when needed.
I understand that this could be a lot of work to do, and I also understand that some of these features I've requested are useful/wanted only for italian language, so I don't know if you could just teach SK to behave differently when the italian dict is selected, or if it would be more convenient for you to add an "italian mode" check box to the settings in order to implement these features.
I also would like to know from others italian users what they think about the single tapping feature request.
Thank you for your attention, and thank you for the great work you are doing with SKP.
