Gingerbread Green Themed Keyboard REQUEST
inate71
This is sort of a tall order, but I'm hoping someone is up to the challenge. :)
Here are the pictures. The Suggestion Bar "suggestions" should also be green, not orange. Also, this keyboard can be found on the Project Elite ROM. The HEX for the color can be found in one of the pictures. :)
This IS a themed Gingerbread Keyboard, but I'm sure you already knew that. :P
Thanks so much. :) PM me if you need additional details.
External image (i.imgur.com) External image (i.imgur.com) External image (i.imgur.com) External image (i.imgur.com)
c00ller
You may not like this reply, but go here and download Gingerbread.zip http://www.dexilog.com/smartkeyboard/fo ... =13&t=1426 and extract
Then read these two posts by cyril
http://www.dexilog.com/smartkeyboard/fo ... f=13&t=477
http://www.dexilog.com/smartkeyboard/fo ... 6379#p6379
And start theming! ;)
inate71 wrote:The Suggestion Bar "suggestions" should also be green, not orange.
This is easily done by adjusting the values in the 3rd link above. That's what I did and I came up with this simple change in a matter of minutes:
http://www.dexilog.com/smartkeyboard/fo ... =13&t=1435
In skin.xml there is also an easy way to change the color of the numbers 123... above qwe... look at <colors> in skin.xml
The keys will require more work of course, but for anyone fluent in image editing it should be a piece of cake making the key backgrounds darker and giving a green tint to the key pressed images. Unfortunately I'm not good enough to do this last step but hopefully the above suggestions can tide you over until you find someone who can complete it.
inate71
c00ller wrote:You may not like this reply, but go here and download Gingerbread.zip http://www.dexilog.com/smartkeyboard/fo ... =13&t=1426 and extract
:shock:
This kinda stuff is way over my head. I've been working at it for few hours, and can't get anything to display properly.
jeckert21
Looks outstanding! Can't wait to see the finished product....
inate71
Dude, that's actually better than what I had asked for. I do enjoy the "pop" effect the keys have. This really is awesome. Would it be possible that you theme this to a Gingerbread keyboard? I'll pay you for your time. :)
inate71
stealthychief wrote:Yeah sure no problem, shouldn't be that hard to do since I have all the images made now. I'll post back here when I get it done. Thanks for the support!
Thanks man, means a ton. :D
inate71
This is incredible. Really, thank you soo much. I really do appreciate it. :)
jeckert21
They are great! Is it possible the make the keyboard background black though?
jeckert21
Green mod keys of each Android & GB if you wouldn't mind? Thanks man!
smoothjeff
[quote="stealthychief"]Hey thanks! I'm going to go ahead and release these as is and people can edit them further if they like. I made two versions one with white mod keys( alt key, # key, go key) and another with green mod keys. All the key presses are the green as shown in the screenshot when spacebar is touched. Hope you guys like them and feel free to pm or comment back if you guys have any requests for other styles of this color green.
Green mod keys - http://www.mediafire.com/file/7gdb4x...Blackout-Green
White mod keys - http://www.mediafire.com/file/gxjkxg...Blackout-Green
The mediafire links don't work, could you re-post these? Thanks the skins look awesome
newklearx3
stealthychief wrote:I decided that I would put these on the market for .99 cents a piece. Here are the links:
Green Keys Download from Market
Green/White Keys Download from Market
You're such a fuckin con. First you rip Popfizz Skins , then you post a million paid skins in the open section. Do you know what the hell open means? I think not. Most your skins are shit anyways. You use the same keys with different backgrounds. Get the hell out of here.
