After recently adjusting my screen density on my Thunderbolt to something lower than the stock settings, I notice most skins stopped working. I am not sure why some still work fine and others do not display. I noticed sometimes even different colors/versions of the same skin have different results. Is there an issue with some file(s) in the drawable folders or something?
Thanks for any info.
Which skins stopped working? Are you talking about the built-in ones or Open skins?
All of the built in skins work perfect. Some open skins work, and some don't. Here are my results:
Windows phone keyboards
do not work
http://www.dexilog.com/smartkeyboard/fo ... =13&t=1643 DarkGreen skin
does not work
http://www.dexilog.com/smartkeyboard/fo ... =darkgreen Slate.Green skin
does not work
http://www.dexilog.com/smartkeyboard/fo ... ilit=slate Droid X Grey Inverted
does not work
but Droid X Grey Black
does work
http://www.dexilog.com/smartkeyboard/fo ... =13&t=1556 MIUI Black No-Transparent
does not work
but MIUI Black
does work
http://www.dexilog.com/smartkeyboard/fo ... miui_black Blackout-Green GB White Mod Keys
Blackout-Green GB Mod Green Keys
Blackout-Green GB Mod All Green Keys
All above
do work, but I cannot find the thread right now
Honeycomb
does work
http://www.dexilog.com/smartkeyboard/fo ... =honeycomb HTC Invert Green
does work
http://www.dexilog.com/smartkeyboard/fo ... vert#p5704 Finally,
Pluto from the Market
does work
https://market.android.com/details?id=c ... rch_result I have tried these at LCD Density 180 - 192. None work. Default I believe is 240, and that works fine with the skins.
